Old 12-08-2008, 01:44 AM   #1
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
Started on new cab for the toy
Got most of the rust cut out since taking pics. Passenger side was the worst side as you can see. Got the new hole cut for the tranny cover. More pics to come. "" "" ""
Daren
04 Chevy Extend cab 2500HD 6.0 Liter 4x4
71 CHEVY 3/4 4X4 402 BB, th400/np205, dana44/eaton ho52 w/4:10-TOY
Rip El Jay
RIP BOBBO'S MOM
88JRFAN is offline   Reply With Quote
Old 12-12-2008, 01:16 AM   #2
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
Re: Started on new cab for the toy
Here is some pics with some of the new panels in place."" The cab corner's suck to get the radius right. But i think i got it figured out."" "" And just a better pic of the driver side."" Now to get the front a pillar and kick panel finished up so i can get the rocker in to check fit. Hoping all goes good, that way i can get the driver side done.
Daren
Rip El Jay
RIP BOBBO'S MOM
Old 12-12-2008, 10:22 PM   #3
ChaseDale3and8
ChaseDale3and8's Avatar
Looks like you're doing a great job to me. Some of that aftermarket sheetmetal is a bear to get to fit but is worth it in the end. Can't wait to see some more pics. ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 12-12-2008, 10:58 PM   #4
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
Thanks for the encouragement Joe. Plan to get more done tomorrow. Been fighting this flu or cold junk. Pics will be coming soon. Daren
Daren
Rip El Jay
RIP BOBBO'S MOM
Old 12-12-2008, 11:15 PM   #5
msgross
msgross's Avatar
keep the pics coming, i'm getting ready to do my corners as well...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 12-23-2008, 11:50 PM   #6
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
Here's some more progress pics. Got most everything welded up. Fit the rocker in it's hole. Not to bad a fit. As usual i need to work with it a little. The door i used didn't fit to well, so i'm going to bring another one over to check the fit. Need to finish smoothing the rest of my welds so i can primer them for protection. Need to buy a 90 degree air tool so i can final sand all the tight corners. Get this side down so i can get to the other side. I was just happy that the body lines lined up. Wasn't sure the bottom one would. "" "" "" "" "" ""
Daren
Rip El Jay
RIP BOBBO'S MOM
Old 12-23-2008, 11:55 PM   #7
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Looks like it's coming together nicely, nice work!
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-24-2008, 12:02 AM   #8
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
Thanks Nate. Hope to have it all done while i'm on vacation. If not, were working 32 hrs next month, so it'll make it even easier to get it done. I wanted to get some pics up for Mike on the cab corners also.
Daren
Rip El Jay
RIP BOBBO'S MOM
Old 01-18-2009, 12:13 AM   #9
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
New update. For the most part i have the passenger side done. Just need to finish smoothing down all the spot welds. And as said before, cab corners suck to get lined up. I would definitely do them different next time. But it fits as good as i can get it. Here are some new pics. "" "" "" "" ""
Daren
Rip El Jay
RIP BOBBO'S MOM
Old 01-18-2009, 02:44 AM   #10
ChaseDale3and8
Looking good! I know what you're saying about the cab corners. They are a handful to get to fit correctly. Actually on my truck The rocker and cab corner on the driver side didn't fit like they were supposed to. The gap on my rocker at the back was right, but got narrower towards the front.
I knew the cab corner was going to be a total ***** as soon as I went to fit it up and saw just how far off it was. I was in a big hurry to get it done to drive it again so corners got and I ended up with one big mess. The driver door rubs the rocker now, and the cab corner doesn't line up with the bedside.
It needs to be cut out completely and redone again, but I found a much better cab that I'll be stripping for paint. It only has a rust spot the size of a quarter on the driver side cab corner. It's a 2wd cab that I need to cut the floor on to change to a 4x4 cab. It'll be a lot less work in the end going that way I think, but if I get really ambituous one of these days, I may cut the left side back out again and see if I can fix my mistake.
Just don't get in a big rush like I did because you will end up regretting it later. If you start getting frustrated like I did, just walk away from it for a while. You'll be glad you did. ...Joe
Old 01-18-2009, 12:53 PM   #11
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
I hear what your saying. I sometimes get frustrated to easy, bad for things laying around, they end up getting a feet away from where they were. Yeah i'm going to try and figure a different approach on the otherside. Thanks for te encouragement. Daren
Daren
Rip El Jay
RIP BOBBO'S MOM
Old 01-25-2009, 01:44 AM   #12
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
Made some progress this week. Got the passenger side done other than some finish sanding of spot welds. I'm happy with the results for the most part. At least now i have a better idea on how to do the driver side. Here are a couple pics. Also when all welding is done, i thought of using some kind of paintable silicone sealer on certain spots to help keep water out. That way it doesn't try and rust again. "" ""
Daren
Rip El Jay
RIP BOBBO'S MOM
Old 01-27-2009, 06:33 AM   #13
jdstx
jdstx's Avatar
[QUOTE=88JRFAN;3106211] i thought of using some kind of paintable silicone sealer on certain spots to help keep water out.
You want auto body seam sealer. Looks like youre making good progress on your repairs.
jdstx is offline   Reply With Quote
Old 01-27-2009, 05:39 PM   #14
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
Thanks, i will remember that. As usual they never get done when ya hope. Cold weather doesn't help either, as i try not to work when the garage is to cold to warm up. I also i'. working on it in a buddies garage, so i work around his time table.
Daren
Rip El Jay
RIP BOBBO'S MOM
Old 01-28-2009, 02:18 AM   #15
ChaseDale3and8
Looking good! ...Joe
Old 02-15-2009, 10:17 PM   #16
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
Thanks Joe. Finally got back on the cab again, got the inner rocker tacked in. It is definitely over sized, but i will trim it to fit.Fit the rear pillar so i can get it welded in this week. Further updates to come.
Daren
Rip El Jay
RIP BOBBO'S MOM
Old 02-16-2009, 01:10 AM   #17
nuke1
nuke1's Avatar
hey, that cab is coming along nicely, sure needed a few patch panels in it.
James
1968 GMC "HAVOC"
1986 GMC "Frank"
J.J.R.H. Design & Consulting
My 68`Rebuild "HAVOC": http://67-72chevytrucks.com/vboard/s...d.php?t=316300
A 58' chev build thread: http://www.67-72chevytrucks.com/vboa...d.php?t=311238
1969 Camaro Pro Touring http://67-72chevytrucks.com/vboard/s...61#post3513361
Swiss Cheese: http://67-72chevytrucks.com/vboard/s...d.php?t=384390
Adjustable Trailing Arm How-To: http://67-72chevytrucks.com/vboard/s...d.php?t=321100
1968 Ford Farm Truck: http://67-72chevytrucks.com/vboard/s...=1#post6555587
nuke1 is offline   Reply With Quote
Old 02-16-2009, 05:23 PM   #18
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
Thanks, it has been quite the learning experience, as i've never done any type of body work before. Being a welder by trade probably helps in a way. It looked alot better than the one that's on there now. Hopefully i can get alot of it knock out this week.
Daren
Rip El Jay
RIP BOBBO'S MOM
Old 02-20-2009, 02:13 AM   #19
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
Got the driver side floor and inner rocker welded in tonight. Had to make a floor patch for a rust hole and make the curved part on the front of the inner rocker. Took some work to get it to fit right to the kick panel. Lucky enough there was enough material on the rocker to make it. Just some cutting and fitting to get it to look right. Then had to fill in the rest of the holes after that. Going to work on the floor support tomorrow then get it put back on it's floor to finish everything else. "" "" "" "" ""
Daren
Rip El Jay
RIP BOBBO'S MOM
Old 02-23-2009, 12:17 AM   #20
tim21391
tim21391's Avatar
i wonder whose truck that is in the last pic... haha just kiddin darren... i wish my cab was off chassis like yours it would make life so much easier for us... but i think takin heater and stuff out and wires is more of a challenge then i wanna tackle.. looks good i was wondering how that piece you told me about would fit
1972 C-10...402/400..flowmaster 40 series
1967 Mustang 347 stroker/C-4
1966 Mustang 289/3-speed
2013 Mustang V6/6speed w/300 ponies
I may be 23, but i sure do knows 67-72s are sexy!
Its not MPG its smiles per gallon!
build started 11/25/08
build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796
tim21391 is offline   Reply With Quote
Old 02-23-2009, 01:42 AM   #21
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
Yeah it has made things alot easier. Actually it probably wouldn't be that hard. The wiring harness unplugs on the firewall. Then drain the antifreeze and unhook anything else. The heater and a/c boxes aren't that hard to get off, just some screws. Yeah derek's truck had to make it into a pic. See ya tomorrow.
Daren
Rip El Jay
RIP BOBBO'S MOM
Old 02-23-2009, 04:07 PM   #22
tim21391
tim21391's Avatar
im almost finished with it ill just lay out of the way when i do my spot welds on my supports ill do those in my garage tho later... hopin we can get corners done this week and ill put that driver floor pan in this weekend then maybe next weekend put it on trailer to take home since i broke my air compressor when it hit the street... ryans dad wants it out so i told him after i get the metal work in ill take it home so two weeks should be good i think
Old 02-25-2009, 11:40 PM   #23
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
Some updated pics. Got the front pillar all welded up by now. The gas tank hole is all done, went real easy. Rear pillar is almost done. Put the outer rocker up and it fit real tight, so i'm going to have to play with it. Going to pop the rear pillar loose at the bottom and see what happens. Kick panel is done also. Hope to have most of it done this weekend."" "" "" "" ""
Daren
Rip El Jay
RIP BOBBO'S MOM
Old 03-01-2009, 11:33 PM   #24
tim21391
tim21391's Avatar
lloks good you might beat me... i think im taken a break for a few days haha its too cold for me in my garage now
Old 03-02-2009, 05:17 PM   #25
88JRFAN
LET'S GO RACIN'
88JRFAN's Avatar
We will see. I ended up getting the flu thursday night, so i didn't get anything done this weekend. Looks to be warmer this week, so we will see.
Daren
Rip El Jay
RIP BOBBO'S MOM
