screamin eagle
70 swb 4x4 project
On Sunday Curt dropped off my new truck.I have a 2wd but I always wanted a 4x4.Yesterday I took off the front end and tomorrow I should have the motor pulled.With 54000 miles it doesn't need a rebuild ,just going to clean up and paint.My neighbors are going to love all the parts in my yard!
SCREAMIN EAGLE |
![]() Join Date: Apr 2007
Re: 70 swb 4x4 project
I say when the neighbors start paying your property taxes then they can decide what your yard should kook like. lol Good luck with the new project, your old truck sure looks nice!
Tot Roddin'
Great looking project!
Good luck with it..... and your neighbors. ![]()
-Nate ![]() 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
Sophomore Member
![]() Join Date: Jul 2006
congrats on the purchase, i really wanted that thing, but distance was a huge issue. glad to see it went to a board member and hope the rest of the build goes smoothly for you.
1972 Chevrolet Highlander SWB 1972 Custom Deluxe 3/4 2WD 60k miles these trucks don't need vacuum gauges cause they don't suck! two wrongs don't make a right, but three rights do make a left all i want is a little more than i'll ever get it's better to be judged by 12 than to be carried by 6 |
screamin eagle
thanks-its nice to start w/ a rust free cab,Curt did a really fine job
SCREAMIN EAGLE |
I'm a poor spectator
That was definitely a nice truck.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
goodluck with your project.
1991 1500 longbed: my daily driver ![]() 1937 chevy 2dr sedan. dads project ![]() |
screamin eagle
Today I got the motor and tranny pulled.One of the manifold bolts broke but other then that it went pretty smooth.I bought a wire wheel for my 41/2" grinder to clean the frame and tested one area.I was really surprised how well it came out.
SCREAMIN EAGLE |
A wire wheel on a 4 1/2 works good it's just hard to get into tight spots.
Gotta love oven cleaner.... that DOES get in the cracks and crevices.... (including your lungs though).
"A cat will almost always blink when hit between the eyes with a ball peen hammer" (you don't always have to state the obvious) Wear your PPE! You can eat with false teeth but you can't see with a false eye. 1959 Studebaker Silverhawk 350/400 1972 C10 L6 3OTT 2005 F350 - Built - whew! |
Way to go,Brian.I`m sure you`ll have it lookin`good.
MOVE OVER
nice start,, I've always been good at the tear down,, its putting it back together that takes me too long....
No matter where you are..... There you are... Buckaroo Banzi |
#13 |
screamin eagle
I know what your saying,I have come to terms that whatever I remove I have to put back.I also know just when you feel like giving up you you see the new paint on the body and you get a second wind.
SCREAMIN EAGLE |
#14 |
screamin eagle
today I removed the transfer case.there was a ton of sludge between the transfer case and the tranny.where would you think the leak is coming from?
I ordered most of my parts today including: cowl hood,inner fenders,wheel wells , BDS 4" lift kit +other odds and ends.
SCREAMIN EAGLE |
#15 |
Post Whore
![]() Join Date: Feb 2000
Maybe a bad seal between the two. Were either low on gear oil?
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
#16 |
Probably transfer case seapage.New seals is about all a 205 ever needs.The input and output seals in both the transmission and transfer case should be replaced as well as the lesser seals at this age.Also,any oil leaked from the motor ends up back there.And,grease gets flung of the u-joints and helps coat the bottom of the cab.
#17 |
screamin eagle
It looks like someone tried to reseal the transfer case-this is my dilemma:I am rebuilding this whole truck frame off-do I rebuild a 54000 mile motor and tranny?The motor sounded good and the tranny was a little low on fluid.Today I stripped the firewall and started to work on the frame which was in nice shape
SCREAMIN EAGLE |
#18 |
screamin eagle
today was 60 degrees so I decided to paint the frame w/POR15-it came out nice
I am now in LMC heaven,most of my stuff came today.I also dropped off some metal to be sprayed.
SCREAMIN EAGLE |
#19 |
your in Westbury, NY? A realative of mine owns a used car lot there... and I have family in Lindenhurst, Merrick, East Meadow, and Levittown... and a cousin of min e just moved out of Nassau county to Holbrook.
I love going to visit there, its an awesome place. |
#20 |
I would pull the heads and give a peak into the cylinders....My 70 K10 had only 78K miles on it and ran pretty good....but I found cracked rings in two of the holes....
I mean, if your gonna go this deep into a resto....might as well make sure the power plant is 100% Dan
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 |
#21 |
screamin eagle
tomorrow Were going to tear down the block and see what we have.If the bottom end is good I'll send out the heads and put a mild cam in it w/lifters and chain. THERES NO TURNING BACK NOW
SCREAMIN EAGLE |
#22 |
screamin eagle
well I got the heads back and the motor is assembled It's got a new cam,lifters,oil pump,dist,headers-should be getting the truck tomorrow from the paint shop.Everything is jambed and ready to be put together.One thing I am not happy about is the cost of painting has gone up alot from the price I was quoted but I guess that was expected.
SCREAMIN EAGLE |
#23 |
Beautiful. I'm kinda intrigued with the carb you went with, when it's all up and running i'd like to know what you think of it. I've always wondered about them. It looks great though!!
#24 |
screamin eagle
it funny I had this carb on my other truck and replaced it with a 650 performer and I could swear the truck ran better and faster with the quad.We'll see what happens
SCREAMIN EAGLE |
#25 |
screamin eagle
well I got the body back from paint -the whole truck is jambed. I put in the drive train and installed the 4" lift kit.I hope to finish the motor tomorrow.Also my rims came in 15x10 steelies.they are nice.A few setbacks:steel brake lines didn't fit,wrong u bolts for rear springs,and wrong front sleeves.
SCREAMIN EAGLE |
