Old 12-08-2008, 03:46 PM   #1
Ravenmocker
U.S.N. EOD
Ravenmocker's Avatar
A/C Lamp Socket
I am looking for one of these type light sockets for my AC panel. There's a hole on each end of the back side of the A/C control and it's pretty obvious that they are for the lamp sockets.
One socket only gets voltage when the instrument lights are on and it varies with the dimmer as I would expect.
Does the A/C control get 2 lamps, one on each end?
The wire is gray and comes out of the factory harness.
The wiring diagrams and the owners manual also appear to indicate that there is only one lamp for the A/C controls. It sure looks like there are two socket holes in the back of the control.
Any one have another socket like the one pictured? One of my works the other is destroyed. '72 Stepside
Ravenmocker is offline   Reply With Quote
Old 12-08-2008, 04:20 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: A/C Lamp Socket
It gets 2 lamps, one on each end. Here is a link to what you need, that is for sale: http://67-72chevytrucks.com/vboard/s...d.php?t=318178
leddzepp is offline   Reply With Quote
Old 12-08-2008, 09:15 PM   #3
kamikazekyle05
kamikazekyle05's Avatar
Re: A/C Lamp Socket
where in the harness do these tie in?
kamikazekyle05 is offline   Reply With Quote
Old 12-08-2008, 10:10 PM   #4
blazer72
Freedom isn't Free
blazer72's Avatar
Re: A/C Lamp Socket
one side goes to the dash cluster plug, the other goes to the fuse panel
blazer72 is offline   Reply With Quote
Old 12-09-2008, 09:29 AM   #5
lks dcvn
lks dcvn's Avatar
Re: A/C Lamp Socket
They also should be in the dash wiring harness - grey wire.
lks dcvn is offline   Reply With Quote
Old 12-09-2008, 11:53 AM   #6
leddzepp
Moderator
leddzepp's Avatar
Re: A/C Lamp Socket
I only had one A/C light when I bought the truck. I got another socket/wire and just spliced it into the one already there.
