Old 12-08-2008, 04:00 PM   #1
454_72_4X4
454_72_4X4's Avatar
OEM gauges For sale
No, there aren't for a truck, but I guess they could be used in one.
They're out of a 67 Camaro.
These seem to be between $250 and $450 on ebay. Mine are completely unknown condition I'm thinkin $225 + ride.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 12-08-2008, 04:45 PM   #2
David Johnson
David Johnson's Avatar
Re: OEM gauges For sale
Try www.Camaros.net
David Johnson is offline   Reply With Quote
Old 12-08-2008, 10:42 PM   #3
1969stepside
1969stepside's Avatar
they would look cool in the radio spot and leave the idot lights in the dash no that would be cool imop
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 12-08-2008, 10:44 PM   #4
Rupdog
are they functional, and do you have the console harness to go with? sorry to lowball, but if you can do $125 shipped, i'm in. (90740)
Rupdog is offline   Reply With Quote
Old 12-09-2008, 01:11 AM   #5
454_72_4X4
454_72_4X4's Avatar
I have no idea if they work or not. I'd be glad to do some testing if somebody can tell me where/how to do it. I,\ve got a multimeter, but no sending units for the gauges....LOL
No harness, sorry.
I'm gonna let 'em ride for a while before I drop the price that much, but I'll keep your offer in mind.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 12-09-2008, 01:00 PM   #6
Rupdog
ok. 10-4. i'll wait.
regarding testing:
oil gauge - use a mityvac to supply pressure to the port, or tie into your stock oil pressure port on your engine
clock - 12v to the terminal, and ground the case/back of clock. second hand should start ticking.
fuel - 12v to + terminal, ground to other should cause it to read full. pull ground, and it should read empty. still need to ground the case.
amps - can only check for continuity w/ ohm meter to see if it's fried or not. otherwise, it needs to see amp flow in either direction to show charge or discharge. not sure how to do this other than tying into a charge line off the back of your alternator to your battery + post and start the truck.
hope that helps... (and let me know if i'm wrong here somewhere... hahaha)
Old 12-09-2008, 01:02 PM   #7
Rupdog
WOOPS.... temp works same as fuel. i missed that one!
Old 12-09-2008, 01:33 PM   #8
454_72_4X4
454_72_4X4's Avatar
regarding testing:
Thanks! I'll see what I can do.
One question, are you sure about the fuel/temp gauges? (12v to the terminal) I was thinking (the fuel gauge at least) had a resistor wire running to it?
Oil, clock, amps shouldn't be a problem though.
Thanks!
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 12-09-2008, 10:03 PM   #9
Rupdog
they work off a variable ground concept. 12 volts through the gauge, then through the sending unit (either fuel tank or coolant) to ground. the ground changes as the sending unit changes. for example, when the fuel tank float raises (or lowers), the resistance within it changes, altering the ground. open circuit (no ground) makes the unit read max (or full in that example).
same with coolant sending unit... as temp increases, resistance to ground (intake manifold) changes.
hope that helps.
FYI I have a 67 RS, and could really use these. they won't get hacked up and installed into my truck.
please keep me in line on the list.
rupen
Old 12-09-2008, 10:05 PM   #10
Rupdog
FYI... I got it backwards in the first post: grounding the gauge makes it read low(min), while the open circuit makes it read max.
again, hope that helps!
Old 12-10-2008, 01:06 AM   #11
454_72_4X4
454_72_4X4's Avatar
Cool! Thanks for the info Rupdog. I'll try to get 'em tested tomorrow and post up the results.
Our internet has been down all day today so I couldn't get here to read the testing process you provided, or I might have gotten it done today...
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
Old 01-13-2009, 02:58 PM   #12
454_72_4X4
454_72_4X4's Avatar
Btt..
I did get to test the oil press gauge and it works fine. (I used compressed air)
The clock on the other hand, will not turn either by hand or with 12v. I didn't try really hard to get it to turn for fear of breaking some internal whatnots, but I just wanted it to be known.
Open to offers.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
