Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1988-1998 GMT400 Chevy & GMC Pickups Parts Board
Old 12-08-2008, 07:17 PM   #1
faribran
WTB GM vortec intake bolts
Want to buy a set of 8 GM Vortec Intake bolts..SBC
Let me know what u got.
faribran is offline   Reply With Quote
Old 12-11-2008, 01:36 PM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: WTB GM vortec intake bolts
I don't have any, but just got done putting a hybrid TBI intake onto a Vortec motor. FYI, there is nothing special about the bolts, unless you are going for the "stock" look. They are 5/16" diameter. I forget the length, but it seems they are about 1 1/2" long. I pulled the stock bolts out and used longer bolts to attach the engine to the lift when i put the engine in. A hardware store should have them, or GM parts. I could imagine that GM will be high $$$ though.
WIDESIDE72 is offline   Reply With Quote
Old 12-17-2008, 02:31 PM   #3
faribran
yes.. you are "right on the money"
in more ways than one.... the bolts
are plain... i ordered some from GM...
the counter guy let me see them...didnt buy them.
i got some from my NAPA store..
GM lists for $5.00 and some change for each.. EACH bolt... grrrrr.
thank you for your input.
Old 12-22-2008, 04:57 PM   #4
Hog
They come with sealant applied to the threads dont they? Also dont for get the 11 lb/ft torque spec.
New GM gaskets(ones with the metal anti crush tabs) or the FelPro problem solver gaskets are the way to go.
Goodluck
peace
Hog
Hog is offline   Reply With Quote
Old 12-27-2008, 05:05 PM   #5
faribran
Hog, yes, thank you.. good info
Old 12-28-2008, 01:00 PM   #6
Z16
Just order the ARP ones. Better quality and cheaper then GM. Check at your local speed shop for p/n 134-2002 for the factory look ones. 12 point and stainless are also available
And yes, use the Fel Pro Problem Solver p/n MS-98000T gaskets. They will save you a real issue down the road.
98 GMC Sierra Ex Cab, cowl hood, Euro LED lights, 30 bar billet, Whipple Supercharged 350 Vortec: Forged flattops, E-Tec aluminum heads, Comp Cam, Scat crank and rods, Granatelli Mass air flow, Headers, Flowmaster exhaust , Complete MSD Ignition, Custom Tuning, intake spacer , ported throttle body, AC Delco port injection upgrade, Roller Rockers, Power Pulleys. Gear Vendors Overdrive. Soon to hit a dyno. 2/4 drop(for now).
95 Chevy S-10 Ex Cab 4.3 5 Speed 2/3 drop, Euro lights, billet grill, More to come. The Daily Driver
Z16 is offline   Reply With Quote
