Old 12-08-2008, 07:18 PM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
72 Prerunner
Well, I've decided to go prerunner, so with that in mind. Who makes kits for it? Or anything for it. Do I have to go to a 4x4 shop or a spring shop? I want to lift it 4-6" (cinder block length high).
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-08-2008, 08:37 PM   #2
drbyrdman
drbyrdman's Avatar
Re: 72 Prerunner
2 or 4wd
drbyrdman is offline   Reply With Quote
Old 12-08-2008, 09:26 PM   #3
sandking
.....I am working on it.....
sandking's Avatar
Re: 72 Prerunner
I doubt anyone would make a specific "Prerunner" kit for these trucks, but you can make a kit work with some fab skills. Do you have a 2wd or 4wd? What do you plan to do with the truck? Or are you going for the "Prerunner" look?
View my build thread HERE
sandking is offline   Reply With Quote
Old 12-08-2008, 09:32 PM   #4
thirdstreettito
Resident of Here
Re: 72 Prerunner
2WD, its in my sig.
I want the prerunner lift (not too high) so it sits higher than stock but is still 2wd and still has a nice ride quality. Can I just get bigger springs and be done with it?
~Bradley~
Miss having a truck
Old 12-08-2008, 09:54 PM   #5
sandking
sandking's Avatar
Re: 72 Prerunner
Depending on $$, I would go for some + A-Arms up front with coilovers. The rear, just add a set of deavers and some smooth body shocks. This would make a dependable, yet fairly inexpensive smooth riding truck.
Old 12-08-2008, 09:54 PM   #6
Jtrux
I'm a poor spectator
Jtrux's Avatar
Re: 72 Prerunner
Originally Posted by thirdstreettito View Post
2WD, its in my sig.
You probably couldn't go more than 2 inches in the front or rear without further mods. Fabbing something is definitly the way to go but unless your doing it yourself it's gonna cost you.
Sandking is a badass fabricator, i'd find out where he lives and start bringing him lunches. He could probably tell you exactly what to do and how to do it, maybe even show you a few things.
Sorry sandking, i'm not trying to whore you out, it's just that you're really good at this and I thought i'd give some credit where credit is due.
2006 Jeep Unlimited IMPACT ORANGE
1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig
1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!!
1979 Ford F150 4x4 SWB Built Ford Tough!!!
1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!!
Jtrux is offline   Reply With Quote
Old 12-08-2008, 09:56 PM   #7
Jtrux
Jtrux's Avatar
Re: 72 Prerunner
This depends on if he has leaves or coils in the rear. I have a 69 lwb 2wd that has leaves but from what I here it's kinda an oddball.
Other than that you're right about the front, that's probably his best bet.
Old 12-08-2008, 09:57 PM   #8
sandking
sandking's Avatar
Re: 72 Prerunner
^^^ Thanks!! I will take a compliment anyday.
Old 12-08-2008, 09:59 PM   #9
sandking
sandking's Avatar
Re: 72 Prerunner
Your right. In that case, you have half of the long travel done for you with the links. Just beef up the arms and the mounts, add coilovers to the arms and viola.
Old 12-08-2008, 09:59 PM   #10
thirdstreettito
Resident of Here
Re: 72 Prerunner
What are + A-Arms? Would a 90 AMP Flux Wire Welder do what I need?
~Bradley~
Miss having a truck
Old 12-08-2008, 09:59 PM   #11
sandking
sandking's Avatar
Re: 72 Prerunner
.............I will brb, need to eat.....
Old 12-08-2008, 10:11 PM   #12
Jtrux
Jtrux's Avatar
Re: 72 Prerunner
Yeah...it would but if you can get a gas welder IMO it would be better especially something in the 230 volt range. The reason I say this is because it's the suspension of the vehicle. The entire weight of the vehicle is counting on your welds. If you use a cheap welder and don't make good penetration and something breaks, that'll suck...really bad. Stick would work as well. Clean the surface, use 7018 rods, not that crappy 6011 or 6010 and you should be good.
A arms are what mount from the frame to the tires (kinda) and move up and down . The coils go on top of the bottom one and mounts to the frame in a coil bucket. I'm really bad at explaing stuff but just go look at the truck and you'll see what i'm talking about.
Oh btw this is the welder I have and I love it, I picked it up used for 450 with tank, wire, and cart.
Old 12-08-2008, 10:16 PM   #13
thirdstreettito
Resident of Here
Re: 72 Prerunner
Thanks, heh I meant was the "+" for something... I know what A-Arms are...
I have a tiny budget, would an arc(stick) welder be good for patch panels as well as fab work? Is it cheaper? Also, is gas cheaper to run than electric? Does it matter?
~Bradley~
Miss having a truck
Old 12-08-2008, 10:26 PM   #14
sandking
sandking's Avatar
Re: 72 Prerunner
The + in the a-arm was referring to a longer then stock arm. This would allow for more travel and coilover mounting options.
Personally, I would not use anything smaller then a 175, 230 volt welder. The small 110 volt welders just do not give the penetration needed for suspension components. The gas is in addition to the electric.
Old 12-08-2008, 10:30 PM   #15
Jtrux
Jtrux's Avatar
Re: 72 Prerunner
No arc welding if for for heavy duty welding. You could probably tac something together with tiny welding rods but you're just wasting your time. Neither is really cheaper in the long run.
I don't think you understand the gas versus flux. When I say gas welder what I mean is that the welder (which is powered by electricity) uses a gas shielding wire (CO2 and Argon commonly) instead of a flux cored wire. Neither is cheaper to run.
Typically any modifications to a vehicle that requires lowering or lifting or any alterations especially on limited knowledge won't be cheap at all. Figure what you think it will cost and double it. If you're very experienced you can usually get the price down but part of learning to do these things take money. The reason I say this is cuz parts aern't cheap, paying someone to install them isn't cheap and tools to it isn't cheap. It's just how it is.
Old 12-08-2008, 11:39 PM   #16
thirdstreettito
Resident of Here
Re: 72 Prerunner
Thanks for the info. I want to buy a truck bed rack and cut it up and practice welding. What exactly would you recommend? It has to be cheap in price to buy, can do fab work, can do patch panel work too.
~Bradley~
Miss having a truck
Old 12-09-2008, 09:34 AM   #17
Jtrux
Jtrux's Avatar
Re: 72 Prerunner
Well if you're on a budget the Hobart 140(?, it's either 140 or close) is a 110 volt welder that will work for what you're doing, just practice. I still really recommend a 230 volt though. You can find the Hobart online all day on craigslist and you will occassionally see 230 volt Hobarts, Lincolns and Millers too but they will generally cost more.
But look into the 110 volt Hobart, either new or used, I think you would be happy with it.
Old 12-09-2008, 07:29 PM   #18
thirdstreettito
Resident of Here
Re: 72 Prerunner
Thanks! I think I will go with the 2" lift for the winter and lower (4/6) it the rest of the year.
~Bradley~
Miss having a truck
Old 12-09-2008, 07:30 PM   #19
thirdstreettito
Resident of Here
Re: 72 Prerunner
One more thing, where can I get the right size springs?
~Bradley~
Miss having a truck
Old 12-09-2008, 07:37 PM   #20
thirdstreettito
Resident of Here
Re: 72 Prerunner
http://raleigh.craigslist.org/tls/950977456.html
How about that second one?
~Bradley~
Miss having a truck
Old 12-09-2008, 08:15 PM   #21
Jtrux
Jtrux's Avatar
Re: 72 Prerunner
You don't want either of those, first off they are overpriced and the second one is a stick welder, not good for body work.
I thinking lifting and lowering your truck during different times of the year would be alot of work.
Old 12-09-2008, 08:30 PM   #22
thirdstreettito
Resident of Here
Re: 72 Prerunner
Thanks. Work doesnt bother me.
~Bradley~
Miss having a truck
Old 12-20-2008, 04:44 AM   #23
MickMc
MickMc's Avatar
Re: 72 Prerunner
Bradley
Do you already have the truck?
You seem to respond to every post, so you should know there is a way to get the lift without any welding or fabrication...
The lift is easy, next question.
I know you know the answer to your question , you seem to be leading the forum down some path of ???? I can't tell what..
Mick
MickMc is offline   Reply With Quote
Old 12-20-2008, 05:56 AM   #24
1969 GMC
1969 GMC's Avatar
Re: 72 Prerunner
I bet you $10 that swapping suspension components to match the seasons will get old (or that it never even gets executed). Buy a cheap running 4x4 to match your 2by.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
