Old 12-08-2008, 10:21 PM   #1
old1946truck
Exclamation 1947-1959 chevrolet 3/4 ton spindles
I heard that 1947-1959 chevrolet 3/4 ton spindles will mount on a 1946 chevrolet truck. So I can run disk brakes on the front axle.
old1946truck is offline   Reply With Quote
Old 03-12-2009, 12:00 AM   #2
kdrodworks316
KOFFIN DRAGGER
kdrodworks316's Avatar
Re: 1947-1959 chevrolet 3/4 ton spindles
Wow, no replies? I am in the process of doing this same project. I will keep you posted and give you a parts list once I make it all work together.
If the life I live dont kill me, then I guess I'll never die!
New updated stuff at www.kdrodworks.com
My site still needs help, web guys and gals pm me.
the best guys in the whole world:
sweet70beast, jonzcustomshop, runninlow, captainfab, and the one I havent met yet, joe231
kdrodworks316 is offline   Reply With Quote
Old 03-12-2009, 11:54 AM   #3
drummin89
drummin89's Avatar
do you mean 1/2 ton instead of 3/4 ton? there are no brake kits for the 3/4 ton trucks, unless you make your own, but there kits for the 1/2 ton. In fact I swapped out the 3/4 axle front axle for a 1/2 so I can run a 5x4.75 disc brake kit. From what I've been told the axles are the same from 41-59, or at least the disc brake kits work for all those years, with only 1 difference.....when they switched to bendix brakes the lower hole on the spindle ears were enlarged from 7/16" to 1/2".
Hope this helps some
Chris
52 Chevy 3600 (3/4 ton) 5 window pickup
-54 235 Inline 6 w/ Fuel Injection Conversion
-Clifford 2/4bbl Aluminum Intake and Headers
-1/2 ton front axle swap w/ 5lug disc brake kit
-CPP Power Steering Kit
Various pictures of my 52 Chevy 3600
drummin89 is offline   Reply With Quote
Old 03-12-2009, 12:25 PM   #4
dwcsr
Hollister Road Co.
dwcsr's Avatar
41-54 are the same axle 55-59 are the same. The spindles are close enough for the disc kits on 41 -59
dwcsr is offline   Reply With Quote
