Old 12-09-2008, 02:13 AM   #1
HotRodGMC68
HotRodGMC68's Avatar
Anyone used ECE 3/4 to 1/2 ton drop spindles?
hey folks, I'm in the process of my winter project and along the way I decided to ditch the hacked up coil springs and pony up for a set of drop spindles and a new set of springs.
Have any of you used the ECE 3/4 - 1/2 drop spindles and gone to 1/2 ton brakes? If so, did you have any complications with them? and problems or complaints? I trust ECE more than most companies... but a little research never hurt anything!
Thanks a bunch!
Kurt
384 Stroker Small Block-
Best ET: 13.24@103
HotRodGMC68 is offline   Reply With Quote
Old 12-09-2008, 07:33 AM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Anyone used ECE 3/4 to 1/2 ton drop spindles?
I'm interested in this also. I planned to convert my crew cab front suspension this way.
I think you will have to change to 1/2 ton calipers and rotors. Not sure if the rubber brake lines are the same or not.
Subscribing to this one.
Keith
Convert to disc brakes.
Old 12-09-2008, 12:17 PM   #3
chevy_mike
Never Ending Projects
chevy_mike's Avatar
Don't quote me and you'll want to verify with ECE but I think the only difference with the 3/4 to 1/2 ton spindles over the standard 1/2 ton ones is the ball joint and tie rod connections. I think the spindle is the same 1/2 ton one (and uses all the 1/2 ton brake parts) but they have been reamed to allow you to use the 3/4 ton ball joints and tie rods, which are bigger.
1965 C10 Panel, Tiki Express http://www.67-72chevytrucks.com/vboa...d.php?t=506580 SOLD
1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD
1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD
We were given two ears and one mouth for a reason... listen twice as much and speak half as often...
chevy_mike is offline   Reply With Quote
Old 12-09-2008, 03:21 PM   #4
72BlckButy
Tot Roddin'
72BlckButy's Avatar
I agree with Chevy Mike, I would check with ECE as they will be able to give you a 100% yes or no.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 12-10-2008, 01:20 PM   #5
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Interesting, I have no use for them but will tuck this information into the back of my mind.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 12-10-2008, 07:04 PM   #6
Last Chance Kustoms
Last Chance Kustoms's Avatar
They work great! All you do is take your spindle out of the truck and replace with the conversion spindle...They work with the 3/4 ton ball joints and allow you to go to a 5 on 5 bolt pattern and use the 1/2 ton stuff. You just need new backing plates and rotor assemblies. I would also recommend you rebuild the existing front suspension as well. You might as well as long as you are going this route. Anyway, no machining necessary...
Burn-E
Last Chance Kustoms is offline   Reply With Quote
Old 12-12-2008, 03:14 AM   #7
HotRodGMC68
Thanks for all of the replies! Last Chance, thanks for the info! I'll be placing my order with ECE soon!
Best ET: 13.24@103
