12-09-2008, 02:21 AM | #1 |
Under bed gas tank,
Im sure this has been asked a hundred time but what is the best way to do this. I would love to get some insight.
12-09-2008, 02:40 AM | #2 |
Re: Under bed gas tank,
A 69-72 Blazer tank seems to be the prefered method. It fits between the frame rails, the bazer straps fit the tank and the frame, it has all the inlets/outlets for these trucks.
The only thing you have to concider is where you are going to put the filler neck. Alot of guys have put them in the bed in various configurations, a few have hidden them behind a taillight or side marker and still yet some others have grafted a fuel door from another vehicle into the bedside. All the various places to locate the fillerneck look good, it's just a matter of what will work for you/ how involved do you want to get. In the bed floor is probably the easiest, inside the bed on the bedside isn't hard, behind the sidemarker is fairly simple but can be time consuming and behind the tail light or in the stake pocket would be the two most involved. You can find any of these through the search feature for further referance. Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub |
12-09-2008, 03:22 AM | #3 |
I'm not sure where the Blazer tank mounts but if it was to be infront of the rear axle I always thought I would leave the filler neck where it is run the fill pipe down trough the floor then back to the tank.
12-09-2008, 04:43 AM | #4 |
here are a couple pics of the blazer tank in the rear of a truck frame,,,
Attachment 410515 Attachment 410516
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub Last edited by sick69; 07-01-2009 at 09:09 AM. |
02-21-2009, 03:51 AM | #5 | |
Cable -K5 Blazer 2wd: 6.0 LQ4, 7875 Turbo, Tick Stage II Turbo Cam, Built 4L80e, RevMax Billet 3600, 9.5" 14 Bolt -Chevy 3+3 Crew Cab Dually: Cummins 12v P-Pump Swap, Compound Turbos, A2W Intercooler, NV4500HD, 4wd conversion, Radius Arms, Coilovers, Crossover Steering, etc Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=803608 |
02-23-2009, 04:35 PM | #6 |
What do you do about the existing filler neck on the cab. Is there any place that sells a patch for them?
02-23-2009, 04:59 PM | #7 |
I am a Referee of life.
There are patch panels avaiable for the tank hole,though I don't remember who has them a vendor can probably help.The Blazer tank works well though there is some interference from a frame crossmember.The fuel line is simple on a LWB since a Suburban line should work out almost if not perfect.The drawback I have seen posted is that the Blazer tank does hang down and shows below the bumper(depending on the bumper used.
I personally have never had a problem with the Blazer tank and have run them in every 67-72 I have owned.That is because they are the same on Panels and I've only owned 67-72 trucks in a Panel body style.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" Last edited by PanelDeland; 02-23-2009 at 05:00 PM. |
02-23-2009, 06:18 PM | #8 |
WTB this ad
There was a guy here on the forum that was making the patches and giving them to anyone that was making a donation to the "underhaulin" project. You can go to the projects section at the top of the page and see if the info is still in the thread.
02-27-2009, 02:24 PM | #9 |
Member of the longbed union.
sick 69 is that a lwb frame, I'm trying to figure out how much room I'm going to have to put my air tank behind or infront of the tank. This is the size do you believe it will fit without problems? Length - 32"
Diameter - 9.5" Height with legs - 11.5"
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
02-27-2009, 04:05 PM | #10 |
i got my filler neck patch panel from a guy on ebay. paid $12bucks and it was a perfect fit. only thing was it took 3weeks cause the dude was from canada. just type in 67-72 patch panel under ebay car and truck parts. sellers name is infanti72
03-13-2009, 11:42 PM | #11 |
the second pic is my truck. i just put the bed on and the tank hits the bed floor. didn't know this would happen pretty pissed at this point.
03-14-2009, 08:18 AM | #12 |
WTB this ad
When you use the blazer tank the bed sill that runs above it has to be trimmed.
03-14-2009, 08:43 AM | #13 |
Here is a universal Summit tank.
03-14-2009, 09:17 AM | #14 |
Those aren't my pics. I have the tank,straps but haven't put them in yet. I did get the filler neck put it behind the sidemarker light, but thats as far as it went before the weather hit the cold mark. Weather is starting to warm up so I'll get back on it asap.
Frank
70 chevy lwb c10 454/th400 and a 9" rearend suicide doors, marker light fuel fill, 4" cowl , mini tub Last edited by sick69; 03-14-2009 at 09:18 AM. |
03-14-2009, 01:49 PM | #15 |
What part number?
How did you secure it to your frame? Thanks!!
03-14-2009, 05:56 PM | #16 |
Sending her "south"
What's the capacity on that one? Like the fit but would want to stay in the 20 gal range. Was also thinking of using the old cabside filler neck location for a frenched power antenna. Anyone done this?
Terry Hall No such thing as a finished project It's either in progress or SOLD |
03-14-2009, 06:47 PM | #17 |
03-25-2009, 02:01 PM | #18 |
Sofa King Crazy!!
Hey guys, here is a thread going on with some of the same issues, enjoy!
http://67-72chevytrucks.com/vboard/s...d.php?t=335041
You found the Tater. My Blazer Build (New) - http://67-72chevytrucks.com/vboard/s...d.php?t=654650 My 67 Build - http://67-72chevytrucks.com/vboard/s...d.php?t=335650 67 Chevy LWB big window a/c AKA TOTALLED BY A JACKASS. 1972 2wd Blazer "Porterbuilt and Sloshed" |
04-24-2009, 07:32 AM | #19 |
04-24-2009, 08:00 AM | #20 |
Here is the linky. I will put some better pics on tonight with how I made the straps and mounting.
http://store.summitracing.com/partde...5&autoview=sku |
04-24-2009, 08:19 AM | #21 |
I'd like to find someone who can fab up a replacement for my original saddle tank (camper special, guess it was a dealer option... mounted under the bedside behind cab, drivers-side). Mine is RUSTY! Must have been 3 gallons of rusty water in that tank when I pulled it out.
Either aluminum or stainless steel would be nice.
"Two rules get you through life: If it's stuck and it's not supposed to be, WD-40 it. If it's not stuck and it's supposed to be, duct tape it." |
04-24-2009, 08:21 AM | #22 |
Grandpa in the rustmobile...
ram man thats a beattiful frame ya got^^ lol lookin forward to the pics
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
04-24-2009, 09:09 AM | #23 |
Under Construction
There are a few options, you can purchase a aluminum tank from Fuel Cell guy who is a member on this board, you can purchase from nolimit.net etc as well. I have attached a nolimit tank that we installed in my son's '67
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 04-24-2009 at 09:12 AM. |
04-24-2009, 08:33 PM | #24 |
Here are the pics. $150 summit universal tank. The top supports are 1" square tubing and the straps I bent up from some 1/16" 1" flat. The current filler location hits right on the bed crossmember. I am going to box that area in underneath and have a flip open door in the bed, or move the fill cap to one of the corners of the tank, or put a 90 degree off of the top and route it out to the side. Anyway I think it is a pretty inexpensive tank relocation.
04-24-2009, 08:35 PM | #25 |
couple more
