Serpentine Swap Questions
I understand that you can use the S-10 V-6 serpentine set up to swap over on a Small Block. Using that setup do you have to do anything to the power-steering pump or are the pressure settings the same? Where have you mounted the remote reservoir for the power stering?
My Truck's not leaking its marking its territory! |
| Bookmarks |
