12-09-2008, 12:20 PM | #1 |
Formerly- 1972SuperCheyenne
Wanted... 3.42 gears and posi
Need a set of 3.42 gears and a posi unit for my 72. A rebuildable unit would work fine. Not trying to break the bank right at Christmas so take it easy on me fellas.. Thanks
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
12-10-2008, 03:14 AM | #2 |
Re: Wanted... 3.42 gears and posi
i've got a set of 3.42's that came out of my '69. nuttin wrong with them but, 2 little chips off the inside of the ring gear, should be fine. ill take $40 for them if ya come get them. can post pics if you're interested. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
12-10-2008, 09:14 AM | #3 |
Thanks but I would like to find a set already with the carrier if possible. Thanks again.
