Old 12-01-2002, 01:34 AM   #1
iluvmy72
Lightbulb rear end idea
say I was to upgrade to a 3/4 ton rear end but want 5 lug instead of 8.....would I be able to put the 1/2 ton axles in the shaft or would these not line up or fit correctly or am I looking at more work and a headache to do this?.....also.......someone told me there used to be a company that made adapter plates for this kind of conversion....anyone know or heard of this
iluvmy72 is offline   Reply With Quote
Old 12-01-2002, 01:53 AM   #2
mikep
Used to have a truck
mikep's Avatar
I'm not sure if there is a company that made an adaptor of any sorts but the way full floating 3/4 ton axles work is that you have a stub shaft that goes out to a hub with its own bearings . The stub shaft can break or not even be there if its a positraction and the other side will still drive the truck. Or if the axle does break its a simple matter of unbolting the axle and changing the axle, In most cases you wouldnt even need to pull the wheel. Arent they great? Having said that ... Its not that big of a deal to convert 3/4 ton axles to 5 lug. It costs money but not a lot. $500-$600 or so. Not the end of the world. The flanges on the ends of the tubes get cut off and new flanges get welded on . Then custom made semifloater axles get installed . Curre makes them , dutchman makes them as do a dozen or so other companies. Ive had 5 lug axles made for Dana 60's and had the tube ends welded at Dutchman in Portland Oregon and the total cost was $550 which included parts and labor. Add to that the cost of the 4.10 geared 3/4 ton positraction dana 60 of $50 in the local paper and I had a complete 5 lug 4.10 geared dana 60 with bulletproof axles for $600. This rear end went under a 69 camaro but the same concept holds true if you are doing it for a truck.
No truck :-(
mikep is offline   Reply With Quote
Old 12-01-2002, 02:14 AM   #3
Scrub
Collector of rusty Items
Scrub's Avatar
Dynatrac will build anything you want. I think they have a standard 5 bolt Dana 60, but it isn't full float.
http://www.dynatrac.com/dynatrac_axels.html
Seems to me that there was a stock Dana 60 5 bolt, but I have never seen one.
Do a search on dana 60 on ebay, and you will find some stuff
http://cgi.ebay.com/ebaymotors/ws/eB...tem=1873550472
Not sure about the pattern on that one and kinda high for a drum brake axle.
good luck
Scrub
Sisters, Oregon - Home of the Sisters Rodeo.
70 GMC 1,000,000 + miles
72 K-20 project, 456 Dana60 front, Corp14 rear w/locker, 265R19.5 tires 20-ply. Warn 12k winches both ends, Cross-over steering with raised tie-rod, Powerbox steering, 4500 watt 120-AC power, Air, Hydraulic aux power, 4 inch lift, 5000 lb air-bags both ends.
Scrub is offline   Reply With Quote
Old 12-01-2002, 02:45 AM   #4
mikep
mikep's Avatar
I am the proud former owner of a factory Dana 60 - 5 lug rear end . You wouldnt want one. I believe the pattern was 5 on 4 1/2" . Its whatever the Ford 1/2 ton pattern is. Remember the old road runners, super bees, belvederes, and assorted other chrysler products that came with Dana 60's behind their RB and Hemi 4 speed cars. thats what they came out of. Great concept until you opened one up and figured out they were 10 spline inch and an eigtth axles. You still see some floating around.
I had one under a 67 camaro that I picked up for cheap but it cost me as much to have the axles respined as I paid for the rear end when I had it narrowed. Forget about trying to find one cheap these days. You'd be fighting all the MOPAR guys looking to put one under their over-engineered MOPAR thing ( can you tell I dont like MOPARS ? )
Price on that Ebay one isnt high at all. Remember you're talking about a musclecar dana 60 with a detroit locker in 4.10 gearing. Most came at 3.54 . That rear end is the holy grail of MOPAR rear ends. I paid $450 for one over 10 years ago and that was from a good friend in need of cash. I'd pay over a grand for the same thing these days.
No truck :-(
