Chevy nut
396 in my stepper
My 69 stepper has a 250 6cyl in it. Since the 69 3/4 isnt going to be fixed do to the cab is shot...I am yanking the motor and trans out. I want to slap the 396 in the stepper now. I noticed the shifters are not in the same place as the other. I took the hump out of the 3/4 already since I was assessing the rust damage. since I have never done a 6 to 8 swap....tell me what I getting myself into?
69 stepper shifter. ![]() 69 3/4 shifter ![]() I notice the 3/4 sits further up towards the dash. The stepper shifter sits in the middle of the hump. Is it possible to set the 396 in the 250 position?
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Re: 396 in my stepper
Just change the hump cover too. Put the big block in properly since you have a parts truck to scavenge from.
The tunnel cover simply unbolts and they are interchangable. That way, you have a properly installed big block that fits and functions as good as factory original. All you'll need is a different driveshaft made for the new drivetrain.
Chevy nut
since they are both LWB I should be able to use the other drive shaft.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" Last edited by caminokid; 12-09-2008 at 06:34 PM. |
its all about the +6 inches
if the stepside is a 1/2 ton, then the driveshaft won't swap over... but you MIGHT be able to use the big block's front drive shaft and the stepside's rear shaft, and have it work.
Sounds crazy, but it worked for me installing 1/2 ton stuff into my 3/4 ton burb. |
#5 | |
Resident Curmudgeon
![]() Join Date: Dec 1999
Also, clutch linkage and front springs.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter ![]() Maybe I need to sell some of this crap ![]() Yet another Bozo with a sawz-all |
#6 | |
Chevy nut
![]() Join Date: Jan 2002
The reason the shifters are in different positions is because ones a 6 and ones a v-8. Since you have a complete parts truck, do it right(i.e. motor mounts, etc.). Have fun and ask questions!!
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
