Old 12-09-2008, 06:00 PM   #1
robertspangler
will these doors fit my 79
robertspangler is offline   Reply With Quote
Old 12-09-2008, 06:02 PM   #2
dubdeuce80
dubdeuce80's Avatar
Re: will these doors fit my 79
any door from 73-87(91) will fit, it's the inners that are a little different...
dubdeuce80 is offline   Reply With Quote
Old 12-09-2008, 06:02 PM   #3
robertspangler
what would i have to do .
Old 12-09-2008, 06:08 PM   #4
joe231
joe231's Avatar
77-up are the same.
CHEVY ONLY
Old 12-09-2008, 08:10 PM   #5
robertspangler
so these are just bolt on right?
Old 12-09-2008, 08:14 PM   #6
joe231
joe231's Avatar
yep.
are they power?
is your truck currently power?
CHEVY ONLY
Old 12-09-2008, 08:16 PM   #7
robertspangler
my truck is curently not power, and im not sure if they are or not, what if they are
Old 12-09-2008, 08:41 PM   #8
joe231
joe231's Avatar
you will need the power window/lock harness that runs from door to door under the dash along with the power lock relay. it is all plug and play
here is a thread with some info
http://67-72chevytrucks.com/vboard/s...d.php?t=314764
CHEVY ONLY
Old 12-09-2008, 09:22 PM   #9
bigblock73
yeller
bigblock73's Avatar
Those doors have factory power mirrors...NICE find.
77-91 doors are identical, 73-76 are different on the inside (along with the guts).
bigblock73 is offline   Reply With Quote
Old 12-09-2008, 09:48 PM   #10
joe231
joe231's Avatar
dang Jeff, are you clairvoyant, or do you just have ESPN?
CHEVY ONLY
Old 12-10-2008, 03:04 PM   #11
turbotank
turbotank's Avatar
You gotta tell me what those came off of!!! They look like they have the later style sail mirrors on them!! Must have come from a 90-91 blazer suburban. I didn't know they came factory on those,always thought they had dumbos!!! Lemme know.
The general is always in charge
You guys did this to me!!!!!!!!!!!!!!!!!!!!
turbotank is offline   Reply With Quote
Old 12-10-2008, 03:40 PM   #12
robertspangler
they are off of a 91 suburban
what does everybody think these are worth, they are asking 100 EACH i offered 150 for the pair i will find out soon if they accepted.
Old 12-10-2008, 05:12 PM   #13
bigblock73
yeller
bigblock73's Avatar
$150 a pair is a smokkin deal. I personally would have no problem paying $150-200 for each if I needed them and they were in as nice of condition as they appear. I have seen the mirror setups go for 200 and up on eBay!
Old 12-10-2008, 06:51 PM   #14
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Definitely worth it. They were available on the late 89-91 Suburban and Blazers with Silverado trim. They were also an option.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-10-2008, 07:56 PM   #15
robertspangler
Sweet!!! They just took 150 for the pair and they are power everything, so i have to figure out all the wiring i need, wish i had some pictures of where the wire is on this.
Old 12-10-2008, 09:08 PM   #16
robertspangler
i have a question, since these are out of a suburban, wont they have the power switches to roll like the rear windows down. well i realy dont want those so do they make a switch plate that only has the front windows/
Old 12-10-2008, 09:17 PM   #17
powerdriver 1958
Kid's Mechanic
powerdriver 1958's Avatar
I had to go look and see if mine were there,these are off a later model burb also.100 bucks and electric but plain mirrors
powerdriver 1958 is offline   Reply With Quote
Old 12-10-2008, 09:33 PM   #18
robertspangler
identical other then the mirrors, these are in the town i live in to boot so like 5 or 10 min away from me, i just hope that i can figure out how to install them.
Old 12-10-2008, 11:36 PM   #19
powerdriver 1958
Kid's Mechanic
hanging them is not hard but the wiring will take time time.Maybe we can go though it together.mine has electric doors already but was added and that wiring will come out
Old 12-10-2008, 11:54 PM   #20
robertspangler
do they not hang in the stock spot?
Old 12-11-2008, 12:01 AM   #21
joe231
joe231's Avatar
just go to the junk yard and get you a power window/lock harness, and a double window switch for the drivers door, (you might also need the wiring from a pick up door not sure)
CHEVY ONLY
Old 12-11-2008, 12:12 AM   #22
turbotank
turbotank's Avatar
Yeah,that was the first time I had ever seen those mirrors on one of our trucks!!! I wonder,will they bolt in the same place as the dumbos? I have always liked that newer style of mirror,folds right out of the way easy!
Old 12-11-2008, 09:01 AM   #23
thinair
thinair
thinair's Avatar
if you bolt them in the same spot,you would not be able to open the wing windows
thinair is offline   Reply With Quote
Old 12-11-2008, 09:44 AM   #24
joe231
joe231's Avatar
huh?
CHEVY ONLY
Old 12-11-2008, 09:47 AM   #25
bigblock73
yeller
bigblock73's Avatar
The power mirrors are moved to the rear of the door slightly so that you can open the vent windows. If they were bolted in the same place as the dumbos, it would prevent the vent window from opening because they sit closer to the glass than the dumbos.
