12-01-2002, 01:49 AM | #1 |
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Was there a speacial sealant used for the top of the windshield frame
On my 71 Blazer,the top sits on the top of the winshield frame.There is a drip rail at the top of the windshield frame.I know there was a semi-hard sealant that was applied in that area from the factory.
Anyone know what is was? Will any seam sealer do. I'm doing the paint and body and have removed all the old sealant from this area. Here's a pic to give you an idea what I'm talking about.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE Last edited by BobbyK; 12-01-2002 at 01:53 AM. |
12-01-2002, 12:08 PM | #2 |
I was wondering the same thing as I'm fixing by buddys truck while he's gone and the sealant is pretty much gone on the top of the cab. It's not a blazer but I'm sure that stuff is probably the same for all makes.
69 GMC 1/2 ton lwb, LS1, headers X-pipe 4L60E Yank 3500 stall 3.73 w/eaton brute force. moroso trick front springs,jeep rear springs, QA1's |
12-01-2002, 12:54 PM | #3 |
hey bobby
i dont have that problem on my blazer but make sure the sealant gets semi hard to stand up to the hard top contact/rubbing i am also interested in your 700r4 set up ie: drive shaft,speedo cable,coolant lines,column shift linkage,tv cable,ect. thanks Tim. |
12-01-2002, 01:30 PM | #4 |
Do it well or don't do it
Check with a 3M dealer and get them to research it with 3M they have a tech line available to all dealers.
Try to be the person your dog thinks you are. Excellent paint and body site: http://www.autobody101.com/ Visit my Web Site http://home.attbi.com/~agfosteriii |
12-01-2002, 05:07 PM | #5 |
I use a 3M product called Fast n' Firm.
12-01-2002, 05:57 PM | #6 |
Hey hobby67stepside how did 3M's "Fast-N-Firm set up?
I'm looking for somthing that's set's up kinda hard but has a little give to it. Thanks for the replies guys. BINDER,you can e-mail me with question about my 700R4 intall at blazbk@excite.com
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
12-04-2002, 12:40 AM | #7 |
Bobby. the Fast and Firm sets up but still has some flexibility. I think its as close to original as you will get.
