Old 12-09-2008, 06:44 PM   #1
cochino12
It followed me home?
cochino12's Avatar
Review my checklist for LWB to SWB conversion please
So I have decided to start working on the swb conversion on my 79 3+3 and want to make sure that I have thought of everything. Is there anything I havent thought about?
First, obviously the shortening of the frame. I will be having a shop in town do this for me and will be keeping it 1 ton. Havent found any write ups on shortening a one ton and keeping it 8 lug? Anything I need to know about cut lines or will the be the same as a 1/2 ton, spring location?
Brake lines need to be shortened. I read that you can just buy swb brake lines? is there a distribution block located somewhere behind the cab? if not I guess I dont understand how this would work or do I need to have new lines bent from the location of the new axle to the engine bay?
Fuel line/Tanks, pretty simple right? just need a couple swb tanks and shorten the lines. Any other options here? Maybe a fuel cell in back with hidden filler neck? Needs easy access because it will be a DD
Drive Shaft. Either get mine shortended or grab one from a swb truck.
Electrical. No big deal there
Here are a couple of links (from Captkaos site and a couple here) that I've found with some info
http://67-72chevytrucks.com/vboard/s...highlight=Crew
http://www.73-87chevytrucks.com/lwb_to_swb.htm
http://forum.73-87chevytrucks.com/sm...p?topic=7334.0
Sorry for the redundancy, I just want to make sure I'm not forgetting anything
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 12-09-2008, 07:18 PM   #2
suicide 63
Re: Review my checklist for LWB to SWB conversion please
I would think it would be the same.
Just buy a double flare tool from your loacal autoparts store and reflare it.Their was a junction on mine right at the back of the cab on pass. side.
I used two new 87 16 gal tanks and put my sending units in them.An after thought I would use driver side saddle tank and a blazer tank in the rear ,then relocate the pass. fuel door to the drivers rear side of the bed so both gas doors are on the same side.Around here they no longer use retractable gas hoses so i have to turn the truck around to fill the pass. tank.
will have to be shortend approx. 14 inches
suicide 63 is offline   Reply With Quote
Old 12-09-2008, 07:37 PM   #3
cochino12
cochino12's Avatar
Thanks for the help suicide 63, I was trying to find your build thread but couldnt but I saved it now. You really have me thinking about converting to 6 lug just because of the availabilty/selection of wheels but I realy want to keep it 1 ton. I love the truck, any new pics or progress?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 12-09-2008, 07:54 PM   #4
suicide 63
About the only thing Ive done is put 96 suburban bucket seats and console in ,and got a set of 90-91 power mirrors on.Cut one coil off the front springs. No recent pics.Been driven it like crazy And love the looks from people that Know they have never seen a crew cab short bed of this body style.
Keep us posted on the build.
