Summit rear disc conversion kit
Is the axle flange on the 1971-96 caprice/impala the same as the 12 bolt truck flange? I was looking at the summit catalog today and they have a rear disc brake conversion kit that has a 5x5 bolt pattern. The description says:
Disc Brake, Rear, 11.30 in. Diameter Rotors, 1-Piston Calipers, Parking Brake, Chevy, Caprice/Impala, Kit The instructions also say its for a 10/12 bolt. So I'm thinking unless the flange is different, this should work. It caught my eye because it is the least expensive kit I've seen to date at $479.00 Here is the link. Last edited by jlaird; 12-09-2008 at 07:14 PM. |
#2 | |
Re: Summit rear disc conversion kit
or call the shop (805)485-0382 Justin |
accepting donations
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett |
Under Construction
please share more details!
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
#6 | |
There are two on performanceonline.com, one is $419 and the other is $449. The more expensive one caught my eye because the ebrake is hidden under the rotor. Justin, thanks, I will contact you. josh |
we are about $10.00 under
summit.This price is only good for 67-72 members. The kit is 100%complete and 100%bolt on and even has the rubber brake hoses for your calipers.The price is there so lets see the orders . Justin |
if ypu dont want a parking brake and dont mind firguring out the little things ,look at stock car stuff . strong and a lot cheaper http://www.speedwaymotors.com/GM-COM...PACE,2000.html
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
#10 | |
Still livin the "dream" in '54
Current build. 1954 Chevrolet 3800 "Ella" SOLD! My '67 stepper "Tangerine Dream" "Anything worth doing is worth doing right" James Dean “When you have eliminated all which is impossible, then whatever remains, however improbable, must be the truth.” Sherlock Holmes "There is no spoon." Neo |
VA72C10
![]() Join Date: Mar 2008
Could you source cross drilled rotors to use with that kit? If so, how much more?
Looking for a 67-72 swb or blazer project in or around VA. ![]() |
#12 | |
![]() Shane, go easy on Justin. He is only on this board to help us guys out. I can positively say he would bend over backwards to assist us. All I'm saying is he didn't mean anything by that comment, I think it was just misinterpreted. Ok, off soap box. josh |
#13 | |
accepting donations
Does you kit come with calipers? Will this kit work with 15"x8" rallies?
#14 |
Resident of Here
I had saved a link posted here a while back about a REALLY cheap disc conversion.
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
#15 |
accepting donations
Still got it?
#16 |
Resident of Here
#17 |
Resident of Here
Found it!
http://www.builtbynotorious.com/dibrco.html Lowest price I found in ALL my catalogs is $585, this is a DEAL!
#18 |
![]() Join Date: Jun 2007
Come with a 4 wheel disc proportioning valve?
#19 |
accepting donations
Sweet, thanks man. I can't my blackberry doesn't show the site well so I will look when I get home. Looks like its under 300 but can't tell if that is for the front or rear.
#20 | |
![]() Join Date: Dec 2008
#21 |
accepting donations
This Kit Includes: Rotors Calipers Bearings Seals Hoses Banjo Bolts Dust Caps Spindle Nuts/Washers Cotter Pins
Yup, those are front kits.
#22 |
I did a search a few months ago when I was hunting disk brake pieces for the Dana 60 in my 71 GMC 3/4 ton and found this site which leads to a lot of others.
http://www.thefind.com/search?query=...+brackets&sess[local.active]=off |
#23 |
Anyone have any recommendation for a K10? I could not find any 6-lug conversions on any of the sites, with the emergency brake.
Thanks, Mike |
#24 |
Wow, the kit I linked to in the first post is now $389(all summit brand products are on sale), by far the least expensive rear disc conversion kit ever put together. After all the comments in this post, my original question was never answered. Is the flange the same as a car? If not, I'm thinking it doesnt even matter. I could make a bracket to fit, its just a flat piece of steel. Any input?
#25 |
VA72C10
ttt
