Future TOTM Winner
Anti-dieseling relay question???
Can someone give me an explanation of what this thing does? I am troubleshooting my blower fan and ran into this relay on the diagram. Where is it physically located in my 72 Blazer? I ran a search but couldn't find any details. By the way, I jumped the fan itself to the battery and it spins fine, but somewhere between the switch, the blower relay, and this thing, I guess power is lost.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
Future TOTM Winner
Re: Anti-dieseling relay question???
Well, I have since found this diagram and learned the function of the anti-dieseling relay. Still I am confused on where this thing is and if my truck has it. Was it a year model change?
I'm a poor spectator
Just sell your blazer and buy one that works.
2006 Jeep Unlimited IMPACT ORANGE 1993 Chevy 2500 4x4 ExCab LWB 454/NV4500 Tow rig ![]() 1977 Ford F100 2x4 LWB 1st truck I owned, still have it!!! ![]() 1979 Ford F150 4x4 SWB Built Ford Tough!!! ![]() 1971 Chevy Blazer 350 / SM465 / NP205 UNDER CONSTRUCTION Soon to have a LQ4 6.0!!! |
I have a similar relay that runs over and attaches to the air box near heater coil. It mounted near the top not far from the pass, side vent. Not sure if it is the same thing your looking at though.
"85" Monte Carlo SS "71" K5 (SOLD) "64" Chevelle 1930 Chevy two door rat |
Future TOTM Winner
That's the blower motor relay that is in the upper right corner of both diagrams. I'm assuming they are similar but there is a different number of wires running to them.
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
It's function is to keep the A/C compressor engaged after you turn off the truck. works like a "brake".
If you need the compressor to engage to stop dieseling you've got other problems.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension. Petrolia,Ontario,Canada but working in Port Huron,MI. See ALL my Blazer pic's HERE |
I'm with Jtrux, just sell it dude.
The 72 with Q-jet carb. came with an anti-dieseling selonid, that was just a plunger afair on the carb linkage. That when you turned the key off, it dropped the idle lower to stop it from deseling. But didn't know it had a relay. Mine's been gone for many years. Could that be what you're talking about? Lot of people back in the day used to hook them up to the a/c clutch, to speed the idle up when a/c was on.
This could be way off base but when i wired in my electric fan for the engine i wired it directly to the ignition in the fuse box so that when the truck was running it was on but when i did that when i shut the engine off the truck would keep running and dieseling down to a halt well after quite a bit of beer and head scratching and voltmeter readings as the fan was winding down it was creating a voltage through the windings and back feeding through the fuse box that was keeping the hei supplied with voltage hence keeping the motor sorta running
i used some diodes to correct the problem but then went to a relay and it is all good so with that said could this relay be there to keep voltage from back feeding through the fuse box to the old coil as the fan winds down on shut off?? Just a thought |
Very old thread I know, however if anyone else is looking for the location the anti-dieseling relay it is under the dash to the left of the ashtray near the ignition switch.
Junior Member
i'm pretty sure that the solenid that is on the carb w /ac is to kick up the idle when the air is on .to keep the motor from stalling at idle when the clutch cycles
that's how a lot of guys wired them to their a/c clutch....but originaly the plunger kicked out when you turned the ingnition on and retracted when you turned the ignition off. they were an anti=deiseling device..they used them on all gm cars with q-jets.. at least in 72 air or no air.. still have the one on my 72 centurion with 455. some were threaded into the bracket, and you had to unplug them and turn the selenoid to adjust the idle..others had a hex head and you could adjust just the plunger with a wrench..
#13 |
![]() Join Date: Feb 2003
for those looking for a factory gm # on these. its #6273301
and some on epay.
1971 K5 CST Blazer 1965 Chevelle Malibu 283 (sadly sold) 1968 Camaro 327 1968 Honda mini-trail z50a #377 1966 uh 1-D Huey |
