12-09-2008, 10:31 PM | #1 |
accepting donations
6 lug disc to 5 lug disc
I have disc up front in a 6 bolt pattern, is it as easy as buying a 5 lug rotor to do the swap? If so which rotor would I need?
1999 Yamaha roadstar 1600 chop. (in progress.) See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/ "Ya'll can go to hell, I'm going to Texas." David Crockett |
12-09-2008, 10:34 PM | #2 |
Built 4 Speed
Re: 6 lug disc to 5 lug disc
72 i believe was 5 lug would be the simplest.
i got a 75 front end on mine somehow. just came home that way.
1969 C/10 Short Box: 496/T-56 in worx. "To Be Old And Wise, First You Must Be Young And Stupid" |
12-09-2008, 10:43 PM | #3 |
accepting donations
Pretty sure mine is the stock crossmember but have no idea what brand conversion kit was used.
12-09-2008, 10:47 PM | #4 |
Under Construction
i would think so, you could pull a rotor and take it with you to the parts store and have them mic the 6 lug vs. 5 lug, if the same inner diameter you should be able to bolt up.
if you were not several hours away, i would let you test fit some stock rotors i have in the garage.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 Last edited by my67chevytruck; 12-09-2008 at 10:47 PM. |
12-09-2008, 10:49 PM | #5 | |
accepting donations
I might head to the junkyard on saturday and take a few measurements. Thanks for the offer.
12-09-2008, 10:53 PM | #6 |
Under Construction
yes 71/72 were disk brakes, just did a 72 xmember swap a couple weekends back. the only thing i would be concerned with would be the inner diameter to make sure they both use the same size bearings... good luck.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
12-10-2008, 01:03 AM | #7 |
Chevy nut
Used the whole front crossmember on mine...its out a a 87. I used the power steering out of that truck too.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
12-10-2008, 07:25 AM | #8 |
Watch out for your cornhole !
All of the 6 lug disc conversions I've ever messed with used interchangable rotors with 5 lug. Same bearings, same seals, same calipers and pads.
My 72 short bed actually has 68 model disc brake spindles from ECE. I sold the 6 lug rotors on this board and replaced them with parts store 5 lug rotors off a 73 model.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 12-10-2008 at 07:27 AM. |
12-10-2008, 09:02 AM | #9 |
Under Construction
thanks TX for clarifying this . I was pretty sure they would but errored on the side of caution.
12-10-2008, 10:10 AM | #10 |
Rods
I would be intrested in your six lug stuff. I have a comolaet 5 lug 72 front end
12-10-2008, 06:55 PM | #11 | |
accepting donations
What all was involved with the swap? I have a 87 crossmember and rear diff coming to me from Austin.
12-10-2008, 06:59 PM | #12 | |
accepting donations
Where is Springtown?
12-10-2008, 07:08 PM | #13 | |
accepting donations
Tell you what, I have a 87 front end coming from Austin. You come down to Houston and help me do the swap and you have everything you want off my old crossmember.
12-10-2008, 07:30 PM | #14 |
Under Construction
I think he meant to type Complete 5 lug front end
12-10-2008, 08:56 PM | #15 |
30 miles west of Ft Worth
12-10-2008, 09:06 PM | #16 |
mini truck racer
I was thinging Spring , Texas was Spring town .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
12-10-2008, 09:13 PM | #17 |
where you at in houston he passes that offer up maybe me and you can work some thig out i just got the front end off of a 81 still have put it in yet 5 lug has every thing needed to do the swap let me know
2009 dodge hemi custom paint 86 lwb bagged layin frame 73 2 door nova 54 bel air |
12-10-2008, 09:49 PM | #18 | |
accepting donations
So you want the 6 lug to?
12-10-2008, 09:52 PM | #19 |
ya this way i can keep 6 lug all the way around so i wont have to go and buy a 5 lug rear i paid 250$ for every thing when you say you got a the x member coming you mean the entire brake system?
12-10-2008, 09:58 PM | #20 |
accepting donations
I have everything coming from rotor to rotor.
12-10-2008, 10:02 PM | #21 |
so how much you want for the rotors? ill be putting mine on and my bags this weeken and should be getting my drop spindels soon too
12-10-2008, 11:17 PM | #22 |
Rods
ill take you up on it. when do you want to do it. Ill make the drive. I live in bryan now but thats no big deal. also I have all the tools that we would need to do this too. do you have air?
12-16-2008, 09:18 PM | #23 | |
accepting donations
Only thing I don't have is an engine hoist.
12-17-2008, 12:21 AM | #24 |
Rods
just so happens i do.. I also have a glass bead blaster and a sand blaster if you want to clean them up/// also I paint.maybe powder coat?ok ok so i had a shop in houston before i moved here. Rods Rods....
12-17-2008, 02:11 AM | #25 | |
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride American Born, Country by the Grace of God 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! Last edited by 67ChevyRedneck; 12-17-2008 at 02:12 AM. |
