Old 12-09-2008, 10:46 PM   #1
HOOPTY67
looking for corner carving suspension
has anyone installed a suspension that lowered their square body truck and really made it handle great?
is there a coilover conversion on the market?
thanks!
-mike
HOOPTY67 is offline   Reply With Quote
Old 12-09-2008, 11:37 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: looking for corner carving suspension
you could go with bags from air ride
http://www.ridetech.com/products/Che...-1331-929.html
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 12-10-2008, 11:37 AM   #3
HOOPTY67
whoops i forgot to mention that although the air ride stuff is great, i want to steer clear of air bags on this truck.
-mike
Old 12-10-2008, 11:46 AM   #4
love it loud
Calibration Engineer
love it loud's Avatar
Can't think of anything better than Porterbuilt's c4 dropmember. It's made for a shockwave bag but I'm sure you could run a coilover instead no problem.
CANADIAN CONNECTION
love it loud is offline   Reply With Quote
Old 12-10-2008, 12:07 PM   #5
flamingbig10
6.0 powered square
oh ok, there was one on ebay last year that had coil overs, I think the guy wanted it handle like a nascar
Aaron
Old 12-10-2008, 02:47 PM   #6
AceX
>130dB Moderator
AceX's Avatar
Just a reminder, its a truck. It weighs well in excess of 2 tons. It's not going to handle the road or carve a canyon with grace and stability...
The C4 drop member is for the 67-72's last time I checked. I may be wrong though. If you can get C4 suspension under there, you should be able to get some QA1 adjustable coil-overs for it.
Utilizing the stock suspension, you can lower it, add larger swaybars, increase the spring rate, wider tires, bigger brakes, traction bars, fuel injection, and fuel tank baffles, new bushings, lightweight rims, and most importantly, sticky tires...
Living Life @ 130dB
LED Tail Light Conversion; How-to
Friend. Father. Brother.
RIP El Jay
CLICK HERE and for less than $0.07 a day, you too can help support and build a better forum.
AceX is offline   Reply With Quote
Old 12-10-2008, 02:59 PM   #7
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Porterbuilt has C4 setups for the 73-87's AFAIK.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 12-12-2008, 04:24 PM   #8
82stepside
82stepside's Avatar
My stepside is belltech 3" drop spindles, and 1" dropped coils in the front and a 4" shackle/hanger drop in the rear. I also have their 1 3/8" front sway bar and 1 1/8" rear sway bar. It handles very well considering its a fullsize with a static drop on 17's... Its not the lowest truck but the biggest part of that is lowering the center of gravity on it, and keeping it there as it goes through corners.
Its just like anything else, It depends on your budget, willingness or ability to do creative fab work ect...
For a coilover rear set up you could take cues from the bagged crew and use either a truck arm kit, which essentially turns the rear suspension into that of a 67-72 truck. Its the same basic setup as used in nascars. Im not sure anyone makes a mid-crossmember for that in 73-87 style but check out http://www.hotrodstohell.net/ for what thats all about...
OR
You could get a bolt/weld on 4 link kit from somewhere and just throw coilovers at it rather than bags... but make sure you use a panhard bar or something to keep the rear centered!
Just my $0.02
82stepside is offline   Reply With Quote
Old 12-12-2008, 08:02 PM   #9
killthewabbit
Spear and magic helmet!
killthewabbit's Avatar
I don't think I've ever seen a 73-87 on here set up strictly for handling. I have always wanted to know how those trucks in bigblock73's avatar are set up.
-- Will
killthewabbit is offline   Reply With Quote
Old 12-12-2008, 08:21 PM   #10
Tony_SS
Tony_SS's Avatar
Wide wheels/tires, stiff springs, thick sway bars are all your best bets to improve handling. Go a step further and dial in some neg camber and positive caster for even better results.
Tony_SS is offline   Reply With Quote
Old 12-12-2008, 09:08 PM   #11
flamingbig10
6.0 powered square
http://73-87.com/7387info/Circle_Track_7387.htm
Aaron
Old 12-12-2008, 09:38 PM   #12
piecesparts
Parts and more parts
piecesparts's Avatar
I lowered my 84 and then added the sway bars from Hellwig. I can now put this thing into some pretty nice corners and hold it. It may not do the Gs of a vette, but then again it is a 4000 # SWB truck.
piecesparts is offline   Reply With Quote
Old 12-14-2008, 01:57 AM   #13
killthewabbit
Originally Posted by flamingbig10 View Post
As much time as I've spent on Jeff's site, I've never seen that article. Thanks dude!
-- Will
Old 12-14-2008, 02:51 AM   #14
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
I have a polygraphite kit installed. It holds the road nicely. The truck corner pushes back before the truck tilts over. I can go around underpasses (u turns) at a good rate of speed, but the tires begin to break loose. I would like to tests some better performance tires. Or better yet, find a road course to punish the tranny.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 12-14-2008, 03:21 AM   #15
flamingbig10
6.0 powered square
no problem killthewabbit
Aaron
Old 12-14-2008, 11:30 PM   #16
killthewabbit
I think if I were looking to go for a performance suspension without bags, I'd probably look at the truck arm rear kit from CPP. I thought there was a Fatman Mustang II type front end kit with options for coilovers or bags, but I can't find it on their site.
-- Will
Old 12-14-2008, 11:41 PM   #17
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Roadracer.
http://www.thedieselpage.com/readers/grenwood.htm
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-15-2008, 02:32 PM   #18
Captkaos
Captkaos's Avatar
Simple. They were done like all other race cars, Setup on Grand National Chassis.
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 12-15-2008, 05:37 PM   #19
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
If money is no object then a Porter Built C-4 Drop Member is the way to go, he makes them for coil over & bag applications
Pretty sure he has a rear set up also
But I would prolly try to swap in a 67-72 trailing arm set up in the rear if it were me, like said that is whats used on nascar & stuff, so it should be good enough if you dont wanna spend the money on IRS
Also getting it stupid low is gonna help tons, plus lighter weight will help also
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 12-16-2008, 03:00 AM   #20
oldspowered67C10
I cant help you with the rear, but i did a coilover conversion on my 67. Havent had had drivetime(only drove around 30 miles before I took the body off), but seemed better and now I have choices for spring rate and dampening.
Ill try to post a link.http://67-72chevytrucks.com/vboard/s...d.php?t=266485
oldspowered67C10 is offline   Reply With Quote
Old 12-16-2008, 03:12 AM   #21
Scottshotrods
check out the Scotts Hotrods standard ifs for your truck
one piece crossmember
tubular a-arms
cnc machined rodends
fully adjustable a-arms
fully adjustable coil-overs
on the rebound and spring tension.
You can get our sway-bar for it as well.
big wilwood brakes are options or you can stick with the 11 inch brakes that
comes with it.
power or manual rack
any questions (805)485-0382 www.scottshotrods.com
Justin
Scottshotrods is offline   Reply With Quote
