Old 12-09-2008, 10:58 PM   #1
liljimsrodragz
Building my own tubular A-Arms/"Z-ing" Frame
Anyone built there own A-Arms besides a vendor? Unless of course you vendors want to share your secrets? lol Any tips? I am NOT going to spend 8-900 bucks on a set. I would if this were my only project but I am trying to do this truck for as cheap as possible!
liljimsrodragz is offline   Reply With Quote
Old 12-09-2008, 11:56 PM   #2
72hotrodder
THE TOY STORE
72hotrodder's Avatar
Re: Building my own tubular A-Arms
you will need a welding table thats sterdy. i did a couple of sets for different cars and trucks and you just take your old arms off measure them and i welded a jig onto the table and cut and bent tubing to my liking
72hotrodder is offline   Reply With Quote
Old 12-10-2008, 12:46 AM   #3
Shane
Shane's Avatar
Unless you plan on changing a lot of geometry then there is no real advantage to tubular over the stock stamped arms.
Shane is offline   Reply With Quote
Old 12-10-2008, 01:18 AM   #4
79gmcsierragrande
Manual Transmission Club
79gmcsierragrande's Avatar
I did my own not too long ago I started a thread http://67-72chevytrucks.com/vboard/s...d.php?t=308744 it was a pain in the ass but it was fun.
79 GMC Sierra Grande, SWB, Heavy Half
If I wanted easy I would just buy a NEW truck!
79gmcsierragrande is offline   Reply With Quote
Old 12-10-2008, 01:21 AM   #5
d10s69c10
Built 4 Speed
d10s69c10's Avatar
if you want to go to stock geometry a good idea is to build a jig around the stock arm.
if you can put all the bolts and pipes in the right places and build around the set demensions, with some darn good welds i see no issue doing this yourself.
1969 C/10 Short Box:
496/T-56 in worx.
"To Be Old And Wise, First You Must Be Young And Stupid"
d10s69c10 is offline   Reply With Quote
Old 12-10-2008, 01:38 PM   #6
72hotrodder
THE TOY STORE
^^^ thats how i did it. and i did it mainly to clear my bag and shock mounts. and they just look beter
Old 12-10-2008, 11:13 PM   #7
Twisted Minis
Twisted Minis's Avatar
I had to build some arms for a Crown Victoria that had to have about 2 inches of drop built into them. I couldn't Z the arms because there was almost no room, so I built some with a larger overkill cup that the balljoint pressed into. I used the stock arms to build a jig around, and just made the changes I needed to. I will try to find pictures, I have some of the jig.
If you can find it cheaper, I can fix it!
Twisted Minis is offline   Reply With Quote
Old 12-10-2008, 11:19 PM   #8
Twisted Minis
Here's the ones I was talking about.
The jig.
I used machined cups to hold the balljoint cup in place.
And the balljoint pressed in.
Old 12-11-2008, 01:29 AM   #9
joe231
joe231's Avatar
that is some nice work there twisted!!!
CHEVY ONLY
Old 12-12-2008, 12:05 AM   #10
mygr8ride2000
does anyone know the tolerance between the ball joint and it housing. im looking into building my own control arms as well thanks
mygr8ride2000 is offline   Reply With Quote
Old 12-12-2008, 02:01 AM   #11
Twisted Minis
A press fit should be around .001 to .003 squeeze.
Old 12-12-2008, 02:36 AM   #12
72hotrodder
THE TOY STORE
yep gotta be crazy tight. thats why i used bolt-in balljoints. forgot the part number tho
Old 12-12-2008, 02:44 AM   #13
Twisted Minis
Thats not that tight. The hardest part is machining a tolerance that close. It only takes about a half ton to press them in if they are machined right. I tried a set at .005" squeeze, like the stock arm was, but it really didn't work. I didn't think about the material being thicker, and not wanting to give at all. .002" is usually my number, goes together nice and smooth.
Old 12-13-2008, 01:19 AM   #14
79gmcsierragrande
I went .007 under on the ball joint because it was knurled, and .002 under on the bushings.
Old 12-13-2008, 06:40 PM   #15
MickMc
MickMc's Avatar
Can I hire Twisted Minis to build custom Lower A arms, for my lifted 67?
I like the jig.
Making the jig is almost as much work as making the arms...
Mick
MickMc is offline   Reply With Quote
