Old 12-10-2008, 01:44 AM   #1
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Automatic choke?
Does my 72 have one? Its a 72 C10 350ci original engine/carb/intake. My dad says it has one, but I haven't heard of one these trucks. All help appreciated.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 12-10-2008, 03:33 AM   #2
LuckyHenriksen
LuckyHenriksen's Avatar
Re: Automatic choke?
You mean an electric choke?
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 12-10-2008, 06:56 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
is there a knob on the inst panel that says choke.... like in the 67/68? if not, then it came with an automatic choke.
They became standard in 69 on the 10 - 30 series trucks.
Old 12-10-2008, 08:51 AM   #4
thirdstreettito
Resident of Here
Oh, thanks. Nah, no knob. My dad said it has a choke, I said no dad there is no knob on the instrument panel, then he mentioned the automatic choke, so then I asked on here. I thought that all 67-72's had either no choke or manual choke, but thank God for that guy with a black Longhorn, what was his name? ANDY! If I want a new carb does it have to have a choke? I was thinking of get a trio, triple weber 1b. But its a lot of money, so most likely a Q-Series 650 CFM.
http://store.summitracing.com/partde...5&autoview=sku
Would there be any problem using it because it has an electric choke.
~Bradley~
Miss having a truck
Old 12-10-2008, 08:57 AM   #5
petey-pablo
"THE GREEN GOBLIN"
petey-pablo's Avatar
That would be one sweet looking Carb...............
Petey-pablo
"THE GREEN GOBLIN"
1972 Cheyenne 10 Short Fleet Side
Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs.
454BBC TH400,Posi
1971 Cheyenne 10 Long Fleet Side
454BBC TH350,Posi Sold
Drive it like you stole it!
Petey-pablo@sbcglobal.net
petey-pablo is offline   Reply With Quote
Old 12-10-2008, 08:59 AM   #6
thirdstreettito
Resident of Here
Yeah I think so, the truck will be painted Cummins Apex Red eventually with black details(wheels/engine/etc).
~Bradley~
Miss having a truck
Old 12-10-2008, 10:09 AM   #7
Wrenchbender Ret
All carbs. have chokes unless they are strictly for raceing or are in a multiple carb settup with progressive linkage. The automatic chokes are heated to release the choke as the engine warms up. Some draw heat from the manifold useing vacuum. Some have the bimetal sping in the manifold with a link to the carb. Most anymore use an electrical heated choke. This is the simpliest way to go when changing things around & works the best.
Wrenchbender Ret is offline   Reply With Quote
Old 12-10-2008, 12:18 PM   #8
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I got a new engine wiring harness from M&H Electrical Fabricators and it has the wire for the choke, although my Edelbrock 750 Q-Jet has a divorced choke. It's mechanical and works great.
Member Nr. 2770
Old 12-10-2008, 06:31 PM   #9
thirdstreettito
Resident of Here
Thanks guys it helps a lot. What do I need to convert from a mechanical choke to an electrical one?
~Bradley~
Miss having a truck
Old 12-10-2008, 06:35 PM   #10
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
You first need a carb with an electric choke. Then, you supply 12V (key on) power to the terminal on the choke housing. After that, it's all automatic. Well, you have to "set" the choke by pressing your foot to the floor before you crank the cold engine. If everything is set up properly, the choke will flop into position and you will crank the engine. There should be a choke pull-off that will pull the choke back to the open position as the engine reaches operating temperature.
Member Nr. 2770
Old 12-10-2008, 07:15 PM   #11
thirdstreettito
Resident of Here
Cool! Thanks man! Does anyone make a "kit" to hook it up?
~Bradley~
Miss having a truck
Old 12-11-2008, 12:08 AM   #12
Longhorn Man
do you really need a "kit" to run a wire from the fuse box to the carb with 2 crimp on connectors?
Old 12-11-2008, 09:11 AM   #13
thirdstreettito
Resident of Here
Well I dont know what kind of connector I need. I do crimp/strip/splice wire, but I dont know much about car wires and such.
~Bradley~
Miss having a truck
