wtb front lower crossmember bracket
I need to find both the left and right brackets as you can see in the pics mine are shot.
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 ![]() Last edited by sourkraut; 12-10-2008 at 10:00 AM. |
Gettin By on Gettin By
Re: wtb front lower crossmember bracket
I've got a rolling 67 frame if they are same. I assume they will work. I'll have to check if the ones on it are in good shape. Might be able to get what you need.
69 CST10 LWB 455 Buick 00 S10 2.2 Vin5 76 GL1000 Naked 1bl VW carb "Adios to all the concrete; Gonna get me some dirt road back streets" |
Man that would be great mine is a 67' also! Let me know what shape and price, my zip is 17022. Thanks, Jon
"The way it is" truck build http://67-72chevytrucks.com/vboard/s...d.php?t=359200 ![]() |
Watch out for your cornhole !
![]() Join Date: Jun 2003
Fellas, those aren't brackets, those are the crossmember itself. It's the whole thing, side to side.
i think those unbolt from the member, but i might be wrong. Up at the top where the upper a arm mounts to.
Around #13 up there.
I believe they are riveted.
![]() Join Date: Aug 2006
Ive got a good 3/4t front crossmember, complete w/ drums by my garage.
I dont need the whoel thing just the brackets. I wonder if they would be the same as 1/2 ton?
Also via bolt #18. I think it is bolted also I can check later once I get home after work. To see for sure.
They have 4 bolts that attach to the frame on each side and 4 rivets that attach them to the crosmember on each side that will need to be cut off.
#11 | |
You're gonna have to really work to get those brackets off the crossmember. You've got some rivets to overcome.
![]() Join Date: Jan 2001
I will sell you an entire front end for $50 from a 67 2wd truck. 1/2 TON
very very clean i can leave the power steering box and sway bar with it for a little extra . $75 total i have alot of nice stuff from this 67 if theres anything else your looking for
2004 Silverado 2500HD Crewcab 4x4 2000 TOYOTA 4RUNNER 1971 CHEYENNE LWB (THE LOVE SHACK) 1967 c-10 lwb (THE FARMERS DAUGHTER) Last edited by jc; 12-10-2008 at 09:49 PM. |
#13 |
rivits arn't that big of a deal. Its finding time to get them off that the deal. I'll have to wait untill Sat to get them loose. JC sounds like he has a great deal. Swaybar and PS too.. Xmas came early, wish i could gather that up my self.
#14 | |
could you send me some pics? the other parts I need are the four bedmounts behind the cab for a swb. do you still have those? thanks, Jon
#15 |
let me see what happens with this other deal with JC and I will let you. thanks
#16 | |
ill get pics when i get home tonight yes i have the mounts still here is my craigslist add to give you an idea on some stuff im selling. if theres anything else you need to help make the trip worth your while. http://cnj.craigslist.org/pts/953335688.html
2004 Silverado 2500HD Crewcab 4x4 2000 TOYOTA 4RUNNER 1971 CHEYENNE LWB (THE LOVE SHACK) 1967 c-10 lwb (THE FARMERS DAUGHTER) |
#17 | |
#18 | |
#19 |
for a wood bed right? no
and no i dont make it out your way at all anymore
#20 |
no for a steel bed.
#21 | |
also would you buy chance be interested in a turbo 350? the reason I ask is may be we could do some trading. the tranny works great I had bought a 5 speed(gas mileage). the only thing is it needs the filler epoxied to the base and I could take care of that for you. I also have a trans cooler, factory torque converter and all the lines for it. figured I would put it out there?
#22 |
The LuvShack Garage
If you were only closer, I have one of those crossmembers and
I can't seem to give it away. I asked $40, then $30, then $20, and yes even asked $10 and no takers. Shipping it sux (Heavy)
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
#23 |
That does suck!
#24 |
ill check the ps box next time im out there.
the entire frame would be great if there wasnt 1 spot torched for header clearance. ![]() ![]() ![]()
#25 |
The frame is nice! The brakcets I need are in good shape correct? They are hard to see. The top looks great just cant see lower portion. Is that a lwb or swb?
