12-10-2008, 10:24 AM | #1 |
cab pressure- ac/ heat door vents
Does anyone know if the door louvers at the bottom are there for a reason. I'm wondering about sealing them to keep out the cold/hot and make the cab warmer in winter and ac better in summer.
If the cab is anything like a house, I've heard that there has to be a return air vent (in trucks case, a vent to the outside), to cool or heat properly due to air being forced into room (cab), and if the return (vent) is plugged the room (cab) pressure builds up and the heater/ ac literally stops pushing in any more air. Any thoughts? thanks.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262 http://beerbreadbike.wordpress.com/ Last edited by vtwinsport; 12-10-2008 at 07:26 PM. |
12-10-2008, 10:32 AM | #2 |
Re: cab pressure- ac/ heat door vents
Follow up question to the one above.;
Does the cab draw air form outside when heating or cooling? Or, does it pull air from within the cab to push over the heater core or ac core? thanks.
76 Silverado, 2wd, long box, 350/th350, 3.42 posi, edelbrock performer 64cc heads, edelbrock 1405, 2101 intake, Hedman Headers, Comp Cam XE262 http://beerbreadbike.wordpress.com/ |
12-10-2008, 10:54 AM | #3 |
They are pressure relief valves.
When you slam your doors they vent the pressure to decrease door closing efforts. Also they provide flow thru ventilation to prevent CO build up (a federal requirement by the way) and allow air to be displaced by the hot/cold air you are pumping in. Blocking them will decrease air flow into the cab from the HVAC and will result in decresed and uneven heating / cooling. The input air comes from outside, at the base of the windshield.
1987 2 ton 1982 250/TH350 beater in progress Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping Plus a mess o' tractors |
12-10-2008, 11:50 AM | #4 |
One shot, one kill.
D13 is right 100% with this little added "tweak". IF, a vehicle has A\C, then air can be recirculated without any fresh air from the outside getting in IF, A\C is on and set to recirc. Doesn't matter what temp is set at. IF, controls are set for normal A\C, heat or vent, air will be fresh. Leave door vents alone. The amount of air that gets in there isn't going to effect A\C or heating systems very much. Jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose. |
12-10-2008, 12:07 PM | #5 |
Thanks allot for the info. I figured there would be a good reason for the vents but didn't know what that was. I'll leave em as is.
12-10-2008, 12:49 PM | #6 |
Double 6's
OK, so now I have a question. I totally removed all the A/C so I could lay out. Im sure I will install a vintage air or something similar, but really wanted to clean up the doors visually. Anyone see any real problems arising?
12-10-2008, 03:01 PM | #7 |
www.73-87chevytrucks.com
Those vents have rubber pieces (or suppose to) that allow internal pressure out but not external pressure in.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
12-10-2008, 06:04 PM | #8 |
With the vents blocked your ears will pop everytime you shut the doors with the windows up.
Plus if you run Max AC all the time, the AC pump will run constantly, wasting gas. |
12-10-2008, 07:45 PM | #9 |
Dually Pride
i rode in a 88 truck with sealed vents and good weather stripping and he had to roll down the window to shut the door or else it wouldnt shut tight due to air being slammed in
If I have to explain, you wouldn't understand. '74 Chevy C-30 350/4 speed/dually '94 Ford Ranger |
