Old 12-10-2008, 11:03 AM   #1
kingparts
kingparts's Avatar
Wheel Spacers
How many people have used wheel spacers? I bought some new 6-lug 17" rims for my suburban but I have the heavy duty brakes and the to use these rims I need a spacer or cut on the rim. Anybody have any thoughts or suggestions?
1970 Chevrolet Suburban
1967 Chevrolet C/10 Shortbed Stepside
kingparts is offline   Reply With Quote
Old 12-10-2008, 11:20 AM   #2
Leo70
Leo70's Avatar
Re: Wheel Spacers
I used 3/4 inch spacers on all 4 wheels. I tried the 1 inch but my truck has airbags and when I lower it it rubbed on the inside back tires. The only thing with 3/4 inch thick spacers you have to use smaller lugs and shave if they stick out too far or it would hit the rim.
Ill see if I can take some pictures later.
Leo70
Leo70 is offline   Reply With Quote
Old 12-10-2008, 11:46 AM   #3
orange72c10
Re: Wheel Spacers
I have them on my truck. I think the ride is about the same.
1964 volkswagon, dune buggy
1972 cehvy c 10 with 48000 miles original, bought brand new by my grandfather
1978 chevy elcamino
orange72c10 is offline   Reply With Quote
Old 12-10-2008, 12:21 PM   #4
dmc1
"I'm Walking Deadman's Drive!"
Re: Wheel Spacers
Wheel spacers can be tricky. You need to be careful when using them. You must take into consideration the amount of spacing needed, wheel stud length and the underlying reason for needing them in the first place. I have seen wheel studs snap because of wheel spacers. Since SAFETY is paramount, please take the conservative route. If the wheels are not clearing the outside diameter of your hubs (where the spindle nut goes) and the rear axle flanges are too large, maybe have the inside diameter of the hub hole on the wheels cleaned up the least amount possible at a machine shop or find another set of wheels. This is just my 2 cents. DMC1
dmc1 is offline   Reply With Quote
Old 12-10-2008, 02:01 PM   #5
tcb-1
Nothing to see here.....
tcb-1's Avatar
Re: Wheel Spacers
got 3/4" spacers on the rear of my truck. no problem at all, however I steer away from the cast spacers. go with the solid billet.
Doug
THANK YOU to our American Soldiers & Veterans - POW MIA "You will NEVER be forgotten".
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. Thomas Jefferson
tcb-1 is offline   Reply With Quote
Old 12-10-2008, 02:05 PM   #6
big_al_71
big_al_71's Avatar
Re: Wheel Spacers
I have had them in my sons 96 chevy 1500 for about four years with his 20 inch wheels and have never had any issues...
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 12-10-2008, 02:06 PM   #7
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Wheel Spacers
My opinion is that the load is on the studs, not the spacer UNLESS the spacer is one that bolts to the spindle/axle and has additional studs for wheel mounting. In that case, the bolts still carry the load and the spacer/adapter has a burden on it, too. I have a couple of adapters, from my youth, that fit a 5 on 5 onto a 5 on 4 3/4...or maybe it's the other way around. Seems like it was the latter. Never used them.
Member Nr. 2770
Old 12-10-2008, 06:49 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Wheel Spacers
the lugs are not designed to carry the load. That's the issue. The hub is supposed to do that.
Old 12-10-2008, 07:15 PM   #9
Husker
Husker's Avatar
Re: Wheel Spacers
I have 1.5" on the rear of my 4x4I think it drives a bit better and looks better. The rear is not as wide as the front on stock 4x4's. I also run them on My Cj rear with No problem yet
Ron
Member #111
68 C-10 Daily Driver
70 4x4 Project
76 Jeep CJ-5
Help Support the Board:
He who knows nothing is closer to the truth than he whose mind is filled with falsehoods and errors.
Thomas Jefferson
Husker is offline   Reply With Quote
Old 12-10-2008, 09:30 PM   #10
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
Re: Wheel Spacers
I have 2 1/2" spacers on the rear of my 92 ford dually inbetween the duals. I have truck pulled with them in there, pulled many heavy loaded trailers, and beat on it a lot. It had 550hp last year with 1100ft lbs of torque. I have never had a problem with the spacers and I know my brothers have wacked some curbs with the rear duals as well. As long as you torque them properly and do not stretch your studs you should be fine. And another thing, if you use replacement studs make sure they aren't the elcheapo grade 5 turds. They are prone to break easily.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-10-2008, 09:33 PM   #11
tcb-1
tcb-1's Avatar
Re: Wheel Spacers
amen dieselwrencher! torque them correctly, don't buy the cast el cheapos, and you'll be fine. period.
Doug
Old 12-10-2008, 09:49 PM   #12
69Rob
69Rob's Avatar
Re: Wheel Spacers
so 6 lug to 5 lug spacers will work good then? i just got to make sure that the rim i get to compensate for the backspacing?
2009 dodge hemi custom paint
86 lwb bagged layin frame
73 2 door nova
54 bel air
69Rob is offline   Reply With Quote
Old 12-11-2008, 02:46 AM   #13
Dieselwrencher
Re: Wheel Spacers
IDK about that. Mine are spacers not adapters. And IDK how well the 5 to 6 lug adapters really work as far as how they place the wheel out like you mentioned.
Ryan
Old 12-11-2008, 10:11 AM   #14
matthufham
Re: Wheel Spacers
i got 1 or 1.25 spacers on the rear. had to bring the wheels out some to look right, and haven't had a single problem. 65 dollars total on ebay
matthufham is offline   Reply With Quote
