Old 12-10-2008, 02:52 PM   #1
hotrod 80
mini truck racer
hotrod 80's Avatar
serpintine drive
O.K. I got the serpintine drive from a 99' vortec 350 and in working on the install . What are you guys using or having made up to go from the new pump to the old gear box ? the return line is no biggie , but the high pressure supply line has different fittings . is there a small adapter for the box end to use the new hose ? Cut up 2 hoses and take them to the hydraulic shop ? Also the water pump appears to have 2 heater hoses off of it . Can i just hook my heater up here ? The clutch fan i have is to big for the factory fan shroud also . Any " i have this year and it worked great " would be great . Im also coverting to the CS144 alterator and going to adapt the compressor to my underdash set up .
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 12-10-2008, 03:03 PM   #2
dwcsr
Hollister Road Co.
dwcsr's Avatar
Re: serpintine drive
My setup is from a 91 and I used the stock pressure line. I had to take the pressure valve with the correct flare from the older pump and screw it into the new pump. Then just connect up the hose. For the heater 3/4" hose should come off the intake manifold and 5/8" off the pump. The stock fan and clutch had to go. I riveted a pizza pan to the inside of the shroud and then cut out the hole and mounted the fan in it. So far its working very well for about a year. You may get away with using the stock fan and no clutch.
dwcsr is offline   Reply With Quote
Old 12-10-2008, 07:09 PM   #3
neonlarry
neonlarry's Avatar
I used a BB fan shroud with my setup, clears fine.
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 12-10-2008, 08:57 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Powersteering, just take your 1 inch wrench and swap the fitting from the original pump into the back of the new pump. Then you can reuse your factory hoses.
Old 12-10-2008, 09:03 PM   #5
hotrod 80
mini truck racer
hotrod 80's Avatar
My truck came with manual steering . This is part of the reason for doing this . Really wanted the fan clutch to stay it looks like it will be about an inch from the radiator .
Hey, TX FF you gettin snow ?
1949 5-window
1969 Camaro
1978 Chevy Luv Blue
1999 F350 Dually
Old 12-10-2008, 09:36 PM   #6
Tx Firefighter
Just cold and windy here. No precipitation at all today.
Old 12-10-2008, 10:05 PM   #7
theyammieguy
accepting donations
theyammieguy's Avatar
Hey, TX FF you gettin snow ?[/QUOTE]
Im over by almeda mall and its been snowing here.
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 12-10-2008, 11:00 PM   #8
Tx Firefighter
You got me confused here man. I'm in Springtown, which is in the DFW area. I think you're confusing it with Spring, which is by you.
Old 12-10-2008, 11:35 PM   #9
70 Suburban
Rods
it snowed in bryan tx
70 Suburban is offline   Reply With Quote
Old 12-12-2008, 11:06 PM   #10
a1953mdl
Rusty but Trusty
a1953mdl's Avatar
We used the steering box and crossmember off a 85 when we changed out the crossmemeber to get disc brakes with 5 lug. So when we went with the serp setup, it all worked.
If you need the fitting TXFF is refering to, we should have an extra. Then you would need the appropriate hose.
What year is your steering box from?
72 SWB, 454 / th400... hoping the kids don't get all the parts before it gets built
a1953mdl is offline   Reply With Quote
