Old 12-10-2008, 03:19 PM   #1
mobileortho
mobileortho's Avatar
Wheel spacers
I was wondering if anyone is using wheel spacers on their trucks. I'm looking at purchasing a set of 3" billit spacers to help the rear tires fill the wheel well and centering the rearend. I'll also be using a wider rear tire on the 8" rims. Anyone using spacers?
Robert C.
1950 3600
3600 re-do, shortening it up
If it's true what they say, "You learn from your mistakes,"
I'm a Genius in the making.
mobileortho is offline   Reply With Quote
Old 12-10-2008, 03:37 PM   #2
entourageguy
Yellow truck club
entourageguy's Avatar
Re: Wheel spacers
I'm running 2.5" spacers on my rear.
2 plus years no trouble. Not a lot of weight on them.
I've got about 1/2" between tire and lip. No problems aired up or down.
Brian ......
My hub garage address
http://www.hubgarage.com/mygarage/59apache
I gue$$ everything has it'$ price
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
350 700r lokar shifter
power MII front end, shockwaves
tilt, 4 wheel discs
4-link and bags
10 bolt limited
entourageguy is offline   Reply With Quote
Old 12-10-2008, 03:52 PM   #3
sgtusmc
sgtusmc's Avatar
Re: Wheel spacers
I'm running 3" spacers in the rear as well.
My build, 53 GMC / S10 swap
http://67-72chevytrucks.com/vboard/s...d.php?t=305723
My build, 59 Chevy / 88 fullsize swap
http://67-72chevytrucks.com/vboard/s...hlight=sgtusmc
U.S. Marines - Certified Counselors to the 72 Virgins Dating Club.
sgtusmc is offline   Reply With Quote
Old 12-10-2008, 04:03 PM   #4
Thadious
Re: Wheel spacers
Are you guys running the spacers on the 2wd rears or on the 4x one? And did you go with the stock s10 offset rims or switch to a different set?
I'm working on the s10 swap build up on the frame at the moment while I wait to pick up my trucks.
Cheers,
Ted.
Thadious is offline   Reply With Quote
Old 12-10-2008, 05:04 PM   #5
entourageguy
Yellow truck club
Re: Wheel spacers
My rear is a S-10 4 dr 4x4 in my 59.
I'm running 15x7 ralleys with 70 series.
I think a set of 2" would have been a better choice 4 my truck.
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 12-10-2008, 05:20 PM   #6
sgtusmc
sgtusmc's Avatar
Re: Wheel spacers
Mine is the 2wd s10 rear with stock s10 rims 14x7's.
Old 12-10-2008, 06:14 PM   #7
mobileortho
Re: Wheel spacers
I'm using a Chevy II rear end with 17 x 8 Torq Thrust II's.
Robert C.
1950 3600
Old 12-10-2008, 06:59 PM   #8
Thadious
Re: Wheel spacers
Gotcha. I'm looking at running the stock S10 backspacing on the 4x4 rear axle...now just to decide whether to go with the 3.42 or 3.08 gears with the 4.3 and 700r4
Cheers,
Ted.
Old 12-10-2008, 10:09 PM   #9
entourageguy
Yellow truck club
Re: Wheel spacers
I'd go the 3.42. I'm running a 350 with the 700 r and unless I'm on the hiway I run it in 3rd. Just find the rpm too low around town.
Brian ......
ALL GONE NOW
59 Chev Apache
PRAISE THE LOWERED
tilt, 4 wheel discs
4-link and bags
10 bolt limited
Old 12-10-2008, 11:22 PM   #10
CAL 58 GMC
CAL 58 GMC's Avatar
Re: Wheel spacers
I'm using 2.5 billit spacers. Been on for two years with no problem. I'm running the same rear as entourageguy, but mine is a 2 wheel drive and his was from a 4 wheel drive, 4x4 is wider then the 2x4.
CAL 58 GMC is offline   Reply With Quote
