Old 12-10-2008, 05:08 PM   #1
RANDY COX
RANDY COX's Avatar
Tranny-transfer !
Been a while since Iv'e been on here.I have a question about the tranny and transfercase,On the divorced case is there a seal to prevent the gear oil from the tranny to make it's way to t-case.Thanks Randy.
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 12-10-2008, 06:54 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Tranny-transfer !
Not sure how that could happen since the two aren't connected in a divorced scenario. There should be a seal on the transmission output yoke and one on the transfer case's input yoke.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 12-10-2008, 07:06 PM   #3
RANDY COX
RANDY COX's Avatar
Ok,Thanks I'll have to look at another 3spd tranny to see if there should be a seal,The reason I ask is,I had to replace the adapter that the tranny bolts to and t-case,cause mine was cracked,anywho I pretty sure I had filled the tranny and t-case back up,when shifting the tranny the t-case shifter would make a noise,so I checked the tranny and it was low,so I checked the t-case ,took plug out and it poured like it was overfilled,front end of vehicle was down hill alittle so it lead me to believe that maybe it somehow traveled through that adapter to t-case.Is that possible.Thanks Randy
1964 BBC 402 4x4
Old 12-10-2008, 07:33 PM   #4
Ridgeback
Yes that is possible. You do not have a divorced transfercase so there is a sealing arrangement to keep the trans and transfer lube from mixing.
Ridgeback is offline   Reply With Quote
Old 12-10-2008, 09:24 PM   #5
RANDY COX
RANDY COX's Avatar
Hmm now I'm confused,I thought it was D-I-V-O-R-C-E-D BECOMES FINAL TODAY,Sorry sounded like a song,but my 3spd trans bolts to an adapter,then the trans-case bolts to it doesen't that make it divorced.So it does sound possible,is that what I'm hearing.
1964 BBC 402 4x4
Old 12-10-2008, 09:26 PM   #6
RANDY COX
RANDY COX's Avatar
RIDGEBACK,where are you at in VA.
1964 BBC 402 4x4
Old 12-10-2008, 09:32 PM   #7
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
No yours is married. A divorced tcase is when you have a seperate drive shaft that runs the tcase and is totally seperate from the trans adapter all together.
Ryan
1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread
1972 GMC Sierra Grande Longhorn 4x4
1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed
1972 C10 Suburban Custom Deluxe
1969 Chevy milk truck
1971 Camaro RS 5.3 BTR STG3 Cam Super T10
1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project
Tired of spark plugs? Check this out.
Dieselwrencher is offline   Reply With Quote
Old 12-10-2008, 10:08 PM   #8
RANDY COX
RANDY COX's Avatar
Oh ok,Makes sense,I always thought it was divorced,Hmm Divorced,Seperated,And Married all in the same night,I can't take it.Thanks for the info Gentlemen.Still my question remains will the gear oil travel from the tranny through the adapter to t-case.Thanks Randy
1964 BBC 402 4x4
Old 12-10-2008, 11:00 PM   #9
Yukon Jack
Post Whore
Yukon Jack's Avatar
There is a seal at the tranny where the output comes out, and also where the output comes out of the transfer case. May even be a seal or two in the adapter, I can't remember at the moment. Someone will know for sure, but it is common for them to start letting tranny fluid into the transfer case when a seal starts to fail.
Old 12-18-2008, 02:02 PM   #10
Bentblazer
Bentblazer's Avatar
I had tranny oil leaking out of speedo housing, good indication that tranny seal has gone bad. Drained trans case it was full of gear oil mixed with tranny oil. I have never removed a trans case. My ? is does the trans case mount unbolt by the 4 bolts that are bolted to tranny and the 2 on the cross member and come out as one piece after drive shaft is removed? And also does the front driveshaft need to unbolt or can it come apart and be removed with trans case?
"85" Monte Carlo SS
"71" K5 (SOLD)
"64" Chevelle
1930 Chevy two door rat
Bentblazer is offline   Reply With Quote
Old 12-18-2008, 02:47 PM   #11
Hey Randy,where ya been?It`s good to hear your trans and t-case aren`t getting divorced.I think a temporary seperation (to repace seals) will help make for a marriage that will last.
If I was you I`d be aweful embarrassed knowing I caught those two swappin`fluids.
Old 12-18-2008, 04:16 PM   #12
desertrat
desertrat's Avatar
I had a good come back to that but I better leave that one alone
"Men are like steel. When they lose their temper, they lose their worth." — Chuck Norris
desertrat is offline   Reply With Quote
Old 12-19-2008, 10:14 AM   #13
Yeah,I was ridin`the brakes,too.The word (can`t spell) copulation comes to mind.
Old 12-19-2008, 07:27 PM   #14
RANDY COX
RANDY COX's Avatar
Thanks again,I sure caint have that gearoil mixing with gearoil now can I,What would the neighbors think.guess I'll Have to (REPACE) those seals.Sorry I just had to.
1964 BBC 402 4x4
