12-11-2008, 12:39 AM | #1 |
HERE.......Somewhere
It burned the wire in two
It hooks to the battery and to the metal on the side of the truck. I just dont know whats the problem. the truck was going from half charged to charge and then quit in the middle of the road and lights went slam out
Current rides: 2013 Hyundai elantra gt DD 1995 camaro my first crush lmao Was: 1970 with a 350 4barrel and 288 horses Classics make it possible! |
12-11-2008, 12:45 AM | #2 |
Re: It burned the wire into
how big is that ground wire?
-Scott- 1970 C10 shortbed 396 1969 C30 dually flatbed "Vidalia" |
12-11-2008, 12:54 AM | #3 |
was small it also melted it. It almost cranked you could hear the starter but no fire or could the battery got weak to cause it. Also are you supposed to put distilled water into a batttery?
12-11-2008, 01:02 AM | #4 |
wow
Are you retired too? Nonsense! I'm in my prime |
12-11-2008, 01:15 AM | #5 |
its all about the +6 inches
my god.... your typing is getting worse... try to put a complete thought down... once you can do that, we'll work on a semi-correct sentence.
However, if I am reading this right... you need to check your ground cable... the large one on the neg side of the battery, there should be a large cable going tothe engine, and possibly a small one going to the body. Clean, tighten or even replace these, and let us know what it does. Again... we are assuming that I am able to tell what it is you are trying to say. |
12-11-2008, 01:22 AM | #6 |
that's what i'm getting out of this as well. sounds to me like a bad ground. when i bought my 64 i got a heck of a deal because it "just won't start." I took off the 12 ga ground cable and put the right one back on it. worked great
12-11-2008, 01:42 AM | #7 |
i wonder how many times he was told to clean and make sure he had a bad ground connection?? doubt the skill is there to understand and correct it this time either
12-11-2008, 11:45 AM | #8 |
the skill isn't there to transmit complete thoughts... so you are probably right.
12-11-2008, 12:31 PM | #9 |
Old Skool Club
If you mean the wire I'm thinking about, it is a positive link from the battery, to a terminal on the right side of the fender, across the radiator support and connects to the alternator.
Mine melted one morning.....when the unrestrained wire got against the header on the driver's side and shorted out. If you don't have anything else to use and your mind is racing about how much of your truck is going to remain after all of it starts to burn....you'll pull the glowing wire apart. After some time, the wounds will heal and your hand won't be as tender any more.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
12-11-2008, 01:11 PM | #10 |
Travis,what is burnt?
Which side of the battery is the wire on,+ or -? Does the smaller wire go to a square plastic thing with a nut in the middle on the fender? Does the bigger wire from the same battery post go to the starter or the front of the engine? Are you with me?
12-11-2008, 01:14 PM | #11 |
Real nice of some guys to help while others attack his typing/ grammar skills.
12-11-2008, 01:17 PM | #12 |
Do first what I was to if see ground but fuse circuit but that after...who knows. But thats me just.
1972 K-10 SWB Cheyenne |
12-11-2008, 01:53 PM | #13 |
member #16
Travis look at the diagram and tell us which wire.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
12-11-2008, 02:07 PM | #14 | |
Tim... good point, he may well be talking about the positive side. When he said
As far as raggin on him for typing/grammer.... did you READ that? Have you seen his other posts? I know my grammer/spelling/typing is FAR from perfect... but he isn't even putting complete thoughts down. He can do it, we've all seen a huge improvement on his posting.... but this looks like his early stuff where no one could figure out what the hell he was talking about. |
12-11-2008, 02:45 PM | #15 |
Hey 70 GMC did you get the truck fixed since the tractor trailer hit it? If so look for pinced wires if you hung new steel on it... I think that thread ended up locked like many others you started.. lol
68 C10 Shorty TPI,Bagged, and all the good stuff. Classic trucks feature June 06, On the cover of Jegs Christmas Catalog 08 67 C10 Shorty Shop truck project Bagged and Z'd under destruction and getting nowhere fast. 64 C10 Shop Truck/Daily driver, Bagged, Dropmember, SOLD!!!! Gone but not forgotten.. 54 GMC under the knife getting a S10 chassis swap and bagged. See my build thread... 07 GMC Sierra 5/7 drop, 22's and 24's Air ride on my mind.. http://67-72chevytrucks.com/vboard/s...d.php?t=339340 See pics of my trucks in my profile Last edited by c10addict; 12-11-2008 at 09:54 PM. |
12-11-2008, 08:32 PM | #16 |
Re: It burned the wire in two
It is called "tact".
12-11-2008, 09:23 PM | #17 |
sharp as a marble
Electrical systems in our trucks, like ALL cars and trucks from this era will seek the least path of resistance. NOW, IF you are talking about the ground side of the system, you need two things. ONE is a good clean connection to the battery, and a good clean connection at the other end of the cable to the engine. Shiny clean metal is good. I would also suggest that you make up a small wire 12-14 gauge to connect to the engine and the body. BODY TO ENGINE GROUND. If you wanted to be like me, you would also have an ENGINE TO CHASSIS ground of the same size small wire. Smoke is bad around a battery, and usually it is from a bad connection, or too much electrical load IE bad connections or a starter with a high amperage draw. OH and Andy I have seen you spell!!! HA HA
12-11-2008, 10:45 PM | #18 | |
12-11-2008, 10:49 PM | #19 | |
2nd Q: + 3rd Q: YES!!!! 4th Q: I have no clue. 5th Q: I was till the 4th Question
12-11-2008, 10:51 PM | #20 | |
Never got the moolah or any time to do any thing to it.
12-11-2008, 10:58 PM | #21 | |
http://en.wikipedia.org/wiki/American_wire_gauge
1972 Chevy C-10 Cheyenne Super - Buckets, A/C, "The 17 Year Revival Project" |
12-12-2008, 01:11 AM | #22 |
The big honk'n wires on the battery terminals are closer to 2 gauge (probably 4 or 6gauge). The normal size wires are the 10 or 12 gauge wires.
You should have at least 4 wires coming from your battery terminals. Two wires from each terminal. You could have more wires on the positive side depending on how much extra electrical stuff has been added to your truck Apparently we (meaning you) are concerned with the Positive wires. So, the big honk'n positive wire goes to the starter motor and nothing else. The small positive wire feeds everything else in the truck. You must have a wire pinched, or worn and touching the metal to cause such a burn out. Since we know that your truck has taken some hits, I would suggest you start by looking at the bent up sheet metal against any wires. Inspecting your truck closely costs nothing. Taking a guess and being wrong does. Go slow. Take your time. Ask more questions as you go. Be clear. We will help.
'70 GMC C1500 LWB Power disc brakes. WooHoo! Posi 6 Lug Dana 60 |
12-12-2008, 02:15 AM | #23 |
i assume the the black thing thing travis is talking about,is the junction block and the wires being broken apart is the fuseable link...ie the voltage regulator stuck and tried to overcharge and poppe the fuse or a short that grounded out
12-12-2008, 11:08 PM | #24 |
This is the thing that is hooked up to or grounded. Then the next day wham 18 wheeler beat on its fender
12-12-2008, 11:36 PM | #25 |
It sounds like the fusible link burnt to me
67 C10 Shortbed 327 05 F150 4x4 NO APPOLOGIES 's 02 Xpress X19 02 Yamaha VMax 150 www.xpressboats.com Nothing says 'poor craftmanship' like wrinkles in your duct tape |
