12-11-2008, 01:50 AM | #1 |
4x4 frame!!!
I have a 1963 factory SWB 4x4 frame (not napco) with transmission, transfer case, step bed. I have a title that matches the frame # but it does not have a vin tag. I think you can get a vin tag if you have a title that matches the frame. $1100. I also have a 196? lwb big window decent parts truck if someone is looking to combine the two to build a truck.......Jason
72 Cheyenne Super 80 Silverado Blazer 2wd |
12-13-2008, 12:33 AM | #2 |
Re: 4x4 frame!!!
Do you still have the frame ?
how much rust ? What transfer case does the transfer still work ? Gene Sharp |
12-14-2008, 03:17 PM | #3 |
Re: 4x4 frame!!!
The frame has surface rust only. I am not sure what case is has or if it works. I know it has been sitting for a long time. The frame is actually my mechanics and he has had it for a very long time. If you are interested i can try to find out what case it is if you will tell me what to look for.......Jason
12-14-2008, 09:14 PM | #4 |
Re: 4x4 frame!!!
Should be the Rockwell t-221 transfer case.
