Old 12-11-2008, 10:25 AM   #1
69Rob
69Rob's Avatar
6 lug rotors
Thanx to one of our members i will be receiving 6 lug rotors. now my question is i just bought the entire front end off a 81 now since i will have the 6 lug rotors do i still have to use the tie rods and other stuff off the 81 setup? or will my stock stuff work? i will also be getting 2.5 drop spindels also if that matters any.
2009 dodge hemi custom paint
86 lwb bagged layin frame
73 2 door nova
54 bel air
69Rob is offline   Reply With Quote
Old 12-11-2008, 12:56 PM   #2
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Re: 6 lug rotors
What year are the spindles ???
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 12-12-2008, 12:19 AM   #3
ERASER5
ERASER5's Avatar
Re: 6 lug rotors
Make dead sure that you bought a Heavy Duty brake system unless you are going to get drop spindles, then they will be HD. All the other parts are the same, HD or not. The new-to-you rotors are HD (99.9% sure). The rotors will be 1.5" thick.
Use the '81 tie rods, drag link, a-arms, backing plates, calipers, and spindles. Get the proportioning valve.
Do you have power brakes? Are you going to install power brakes?
A disc/drum master cylinder will be needed.
If you are also adding power brakes, consider buying the MC/Booster as a combo to eliminate mating surprises.
I did this swap during the summer. Best modification yet.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 12-12-2008, 12:53 AM   #4
69Rob
69Rob's Avatar
Re: 6 lug rotors
i have every thing mc/booster every thing so i have to use the 81 parts and i will be buying 2.5 drop spindles this weeken
73 2 door nova
54 bel air
