Old 12-11-2008, 03:25 PM   #1
Krusn64
Krusn64's Avatar
Planning my new frame...need some help
So I've been messing around on the computer trying to plan out my back half frame build...i have no experience with 4 link but i want to install a triangulated 4 link, so if someone could maybe take these pics into paint or something and draw some lines about where the link bars should go that would be a great help...i know that when it comes down to installing the bars my dad will know what to do but I'm trying to plan this as best as i can and he hates looking at the computer trying to figure out what I am doing lol.
Krusn64 is offline   Reply With Quote
Old 12-11-2008, 03:45 PM   #2
kizer
Its Deja Vu time again
kizer's Avatar
Re: Planning my new frame...need some help
I have no idea of what to do, but that rendering is pretty darn cool.
Its not pretty but its mine to figure out.
The build / The Photos / Build Diary
kizer is offline   Reply With Quote
Old 12-11-2008, 03:51 PM   #3
ripdog28
ripdog28's Avatar
If you are running bags or anything with a serious drop just run parallel. come off the outside of the frame off the driveshaft hoop and straight to the axle.
69 c-10 BBC
462ci, forged crank, H-beam rods, 10.5-1 KB forged pistons, Dart Iron Eagle 308cc, Straub Cam, Comp Cams chrome moly full rollers, Weiand Team G, Prosystems 950, TH400/3500 Dalenzie stall, Currie 9+ Detroit Locker w/31spline axles.3.5/6in drop. My Build.
ripdog28 is offline   Reply With Quote
Old 12-11-2008, 03:57 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
Looks like you're headed in the right directon taking the time to plan things out. Sometimes it's easier using someone's (Art Morrison, TCI, etc.) triangulated four link kit with the frame rails since most of the engineering is done for you. Here is a photo from Art Morrison of their triangulated four-link rear clip to give you some additional visual reference. Good luck and post some photos of your progress.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-11-2008, 11:23 PM   #5
PrerunnerRob
PrerunnerRob's Avatar
I'm actually trying to figure this out now. I'm doing a triangulated 4-link, here is what I have learned about set up:
Set frame at ride height-mine is 4" from the ground
set axle at ride height-15" on center
take lower link bars, find a suitable mounting point on frame, and level link.
measure the distance from the center of the axle end link to the lower axle radius. This will give you the height of a tab required to mount the lower link to the axle.
use online 4 link caculator to figure the optimum point for the upper links, and hope it works with your frame. This is where I am right now, but there are quite a few factors that can change the handling of your truck. What are you trying to achieve?
PrerunnerRob is offline   Reply With Quote
Old 12-11-2008, 11:56 PM   #6
scotts62
One day...
scotts62's Avatar
Nice!!
From your drwing there you could run the link bars on the outside of the frame and make/buy a wishbone and brace up the drivshaft loop and run it to that... just a thought anyways.
Scott
93 crew cab build
Project 62
Old 12-12-2008, 02:12 PM   #7
Krusn64
Krusn64's Avatar
hmm...hurry up and finish yours so i just can copy you lol...i was planning on my ride height being 4-5"...i added the lower link bars at ride height in my rendering, im not sure if they are in a good spot but they are level and outside of the frame...i still need to check out that 4 link calculator to figure out the upper link bars...
Old 12-12-2008, 02:48 PM   #8
Krusn64
Krusn64's Avatar
Question Re: Planning my new frame...need some help
what are the pros/cons of having the upper links meet at the center of the driveshaft hoop vs at the center of the axle housing? are there any ride quality improvements that either direction has to offer??
Old 12-12-2008, 03:44 PM   #9
joe231
joe231's Avatar
cool, are you using google sketchup?
CHEVY ONLY
Old 12-12-2008, 03:49 PM   #10
Krusn64
Krusn64's Avatar
yep...it works better than i thought it would it just took some getting used to coming from using solidworks and autocad. im only using the 8 hour trial version which is now expired but i havent found anything it wont let me do yet
Old 12-12-2008, 05:39 PM   #11
joe231
joe231's Avatar
yeah I like sketchup, pretty easy to use
i got the free version a couple years ago, they charge for it now?
CHEVY ONLY
Old 12-12-2008, 06:43 PM   #12
vin63
vin63's Avatar
If it were me, I would land the forward mount of the upper bars to the frame since the driveshaft loop will not have enough rigidity to suport the forces the rearend will place on the bars.
Old 12-12-2008, 06:50 PM   #13
kizer
kizer's Avatar
Unless I'm wrong you probably don't want to really weld to the housing because its cast. You'd be better off welding on the axle tubes them selves.
Old 12-13-2008, 02:02 AM   #14
Captainfab
60-66 Nut
If you're using the 12 bolt, then just bridge over the center section from axle tube to axle tube.....it's done quite often on 4x4's. Of course if you're running a 9 inch it isn't an issue.
I agree with Vin63, run the uppers from center of the diff out to the frame at the front.
BTW I like your 'fish plate' gussets on the frame joints......looks good.
Old 12-13-2008, 02:26 AM   #15
the kid
the kid's Avatar
making trucks pointless 1 at a time
the kid is offline   Reply With Quote
Old 12-14-2008, 07:04 PM   #16
Krusn64
Krusn64's Avatar
thanks guys...i will be running a (BADWORD lol) 9 INCH and i knew you can't weld to the cast on the 12 bolts...i will reinforce the driveshaft hoop if i end up connecting the top links (hadn't thought about that yet)
