12-11-2008, 05:24 PM | #1 |
dual headlights?
I have a 86 custom deluxe with single headlights. Can I put dual headlights like on a silverado without changing the radiator support? thanks in advance.
12-11-2008, 06:12 PM | #2 |
www.73-87chevytrucks.com
Re: dual headlights?
Not unless you want to make your own mounting for the lower lights and the turn signals.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
12-11-2008, 10:33 PM | #3 |
Crazy
Yea what Capt said... You will have to do a good bit of modification to the lower holes to be able to fit lights in them. You will then also need to switch out your light harness for the older one with the two lights so you get the proper high beam, lower beam setup. I don't think it would be a very easy job to do, but I am sure people have done crazier things. You can evaluate what you need to be taking one side of the truck apart and taking the headlight down to the parking light hole to give you an idea of what modifications need to be made.
Good luck.
77 SB Stepside in a bunch of pieces scattered around the garage. |
