Old 12-11-2008, 09:34 PM   #1
aero-pilot
praise the lowered
aero-pilot's Avatar
Question 1982 GMC Suspension Questions
Hello everyone! This might be a very random question but I was wondering if anyone knew what the physical length of the stock rear shackles? I'm asking because I believe that my truck still has the stock shackles with drop hangers on the rear suspension. If this is true then it would explain the stiff suspension in the rear, correct?
I apologize for the quality of the picture.
aero-pilot is offline   Reply With Quote
Old 12-11-2008, 10:03 PM   #2
flamingbig10
6.0 powered square
flamingbig10's Avatar
Re: 1982 GMC Suspension Questions
you have lowering shackles
Aaron
1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot
Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326
flamingbig10 is offline   Reply With Quote
Old 12-15-2008, 10:53 PM   #3
aero-pilot
praise the lowered
aero-pilot's Avatar
Ok then... Additional question... the lower bolt hole on the shackle would decrease the ride height if I moved the leaf down on the shackle? If I'm thinking my physics through that would be right.
Old 12-15-2008, 11:31 PM   #4
flamingbig10
6.0 powered square
thats right
Aaron
Old 12-18-2008, 03:13 PM   #5
aero-pilot
praise the lowered
aero-pilot's Avatar
I'm an idiot! That wouldn't be correct... the shackle is connected to the hanger witch is on the frame! If I were to move the leaf down it would raise the rear end. Thank goodness I didn't do anything yet.
Old 12-18-2008, 03:58 PM   #6
flamingbig10
6.0 powered square
I'm a idiot I thought you wanted to raise your truck, and you can remove a couple of leaf springs and it will help the ride
Aaron
Old 12-18-2008, 07:40 PM   #7
aero-pilot
praise the lowered
aero-pilot's Avatar
Yeah I was thinking of removing the overload spring on the leafs but I still want to be able to pull a trailer if needed. I think I've made my mind up to just go ahead and C-Notch it.
