Old 12-11-2008, 09:58 PM   #1
drewfever1020
original harness?
anyone know were i can order a brand new original complete harness for our tucks?
lmk asap!
drewfever1020 is offline   Reply With Quote
Old 12-11-2008, 10:58 PM   #2
Mudder
Mudder's Avatar
Re: original harness?
Try this page out. Lists vendors that sells parts for our trucks. Some of them help support this forum.
http://67-72chevytrucks.com/links/browselinks.php?c=2
Mudder is offline   Reply With Quote
Old 12-12-2008, 08:36 PM   #3
pickupman
pickupman's Avatar
I have them available. Cost usually depends on options. Let me know if I can help.
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 12-12-2008, 09:54 PM   #4
acl
acl's Avatar
I used Classic Parts (chevy duty) it all went perfect. right length, had correct ends and fittings. Would do again. Gary
acl is offline   Reply With Quote
Old 12-13-2008, 02:00 PM   #5
Psycho71
Psycho71's Avatar
Hmm, didn't we go thru a thread with you a while back on installing an EZ harness? Or was that a different truck?
But yeah, to answer your question, you can get a complete original type harness for your truck through LMC or several of the board vendors I'm sure. If you're just wanting original, you will spend a bit of $$ on all of the different sections of it. But it is done all the time. One of the aftermarket harness' would be much cheaper tho. Just food for thought.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape.
If a hammer doesn't fix it, you have an electrical problem!
Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels!
Psycho71 is offline   Reply With Quote
Old 12-13-2008, 02:45 PM   #6
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
another source is www.wiringharness.com. I've used their stuff and it's good.
Member Nr. 2770
