12-11-2008, 11:07 PM | #1 |
Brakes 66 chevy truck
Changing to front disk 5 on 4 3/4.Want to change rear to 5 on 4 3/4 i know i need to change axles.Drums of from year etc.
12-11-2008, 11:19 PM | #2 |
Rods
Re: Brakes 66 chevy truck
a car
12-11-2008, 11:23 PM | #3 |
60-66 Nut
If you were going with 5 on 5 it would have been easy. Since 5 on 4 3/4 is a passenger car bolt pattern, you'll need to look at drums for a Camaro, Chevelle, Impala, etc. The issue you may run into is finding a drum that will match up to your backing plate. You might be better off to just swap the whole differential.
12-12-2008, 04:43 AM | #4 |
12-12-2008, 09:19 AM | #5 |
It's Better With Nitro
As the others mentioned, the drum brakes make it a bit difficult to change the lug pattern on the rearend. I have a passenger car 10-bolt rear end (5 on 4.75) available that will need rebuilding - it's free, just cover shipping. That might be an easy way to solve the rearend lug pattern issue. PM me if you're interested.
As far as the front goes, I had to re-drill my rotors for the 5 on 4.75 pattern (see photo below).
12-12-2008, 12:02 PM | #6 |
SOLD
Location: Poorest state in America(Breaux Bridge,Louisiana)
80's camaro will work
1966 CHEVY FLEETSIDE SOLD 11-29-9 TRUCK THREAD- http://http://67-72chevytrucks.com/vboard/showthread.php?t=301368&page=2 |
12-12-2008, 12:12 PM | #7 |
Rods
late 80s and you can have rear disk
12-13-2008, 12:07 AM | #8 |
Didn't those come with a 7.5 or 8.2 10 bolt rear end? Just go easy on it.
'65 Chevy shortbed stepside. |
12-13-2008, 02:11 AM | #9 | |
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
12-13-2008, 02:13 AM | #10 |
60-66 Nut
They are either 7.5 or 7.625.....not the best diff IMO. Depends on how much HP or TQ you have. It would work if you don't hammer on it much. A better choice would be of course a 12 bolt or a 8.5 10 bolt.
12-13-2008, 08:45 AM | #11 |
Well the main reason i wanted to change the rear to 5 on 4 3/4 is the rims i want to put on the truck.There are the Billetspecialties street light.They only make the 5 on 5 size 15 by 14 and up.I know where i can get some axles that are drilled for 5 on 5 and 5 on 4 3/4.I did not want to put that wide of a rim on back.
12-13-2008, 07:12 PM | #12 |
SOLD
i've been running a 1980 camaro rearend (rebuilt)for 10 yrs now, and been putting over 500hp to it ever since with a mini spool in it with no problems running high 12s with drag radials. in may i had it narrowed 3" and went with some better axels. i say run it
12-15-2008, 02:34 AM | #13 | |
60-66 Nut
12-15-2008, 09:49 AM | #14 | |
I've had to re-drill countless wheels and rotors for other lug patterns for many years, and I've never had any issues. Many of the drag racers used to drill the magnesium wheels with three different lug patterns in the 60s and 70s with no problems. I figure the rotors are a lot more substantial. The only other option that I could figure was going with passenger car components, and I did not want to go with lighter weight stuff.
