12-11-2008, 11:38 PM | #1 |
Grandpa in the rustmobile...
whats involeved in puttin a th350 trans into my 3sp truck..
Ive located a th350 trans outta a 70 van, is it a bolt up kind thing, or how will it work? Thanks!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
12-11-2008, 11:49 PM | #2 |
Re: whats involeved in puttin a th350 trans into my 3sp truck..
I thought about doing this when my knee was acting up.
I have a cross-member for an auto trans still sitting here. What you will need is either a different steering collumn with the shifter on it or a floor shifter. Then you will need cooling lines and a radiator with a cooler in it. You will need a modulator tube/hose,kickdown linkage,flexplate,torque converter,not sure about driveshaft length. It will take a little doing,not really a "bolt-up" but I don't think it will be too hard. ___and of course the auto trans cross member_________
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. Last edited by WorkinLonghorn; 12-11-2008 at 11:50 PM. |
12-11-2008, 11:58 PM | #3 |
yikes lol more than i thought!
talk to local mech here in our itty bitty town...see what he says bout it
12-12-2008, 12:10 AM | #4 |
i will be doing that soon too my 67 chevy intell my bestfriend dose the 4speed i will be doing some work for the 4speed
12-12-2008, 12:46 AM | #5 |
cross member, shifter linkage & steering column if you want to keep it original. then the labor to install everything
Freedom is never more than one generation away from extinction. We didn't pass it to our children in the bloodstream. It must be fought for, protected, and handed on for them to do the same.... Ronald Reagan Last edited by 72BLUZ; 12-12-2008 at 07:19 PM. |
12-12-2008, 01:49 AM | #6 |
I just did that on my 71 about three months ago...
Very simple to switch if you have time and patience... New Steering column New Lokar shifter linkage New Lokar kickdown New Drive shaft New tilt steering column with shifter Tranny crossmember Tranny lines Tranny cooler New alum. radiator Th350 Built to hold 800hp
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
12-12-2008, 02:17 AM | #7 |
Don't forget new flexplate....you can use the same driveshaft but with a different yoke and it will have to be a slightly different length.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
12-12-2008, 03:20 AM | #8 |
Its not really that hard, it just looks like a lot when you write it all down. I swapped mine form a 3 OTT to a TH400, and I used a Hurst Quarter Stick shifter. It works great. It also depends on if you have the motor out or not. I think its easier to swap them if you have the motor out. You also have to remove the clutch pedal, or just let it swing like me =]
12-12-2008, 07:52 AM | #9 |
mini truck racer
I did this in my 67' and im here to tell you it's a boltin , but not an easy one .
You will need flywheel with bolts , torque converter , trans lineand cooler , steering column , drive shaft shortened and new yoke , shifter linkage , auto cross member , linkage to the 6 (if it's a 6) . and a starter . The starter is what cuase my 6/auto swap to fail . Couldn't find the correct 250/th350 starter so i put a 350 in it . Might be easier if it's a V-8 .
1949 5-window 1969 Camaro 1976 Chevy Luv yellow 1978 Chevy Luv Blue 1976 Chevy Luv Black 1979 Firebird Flooded in Harvey 1999 F350 Dually 2005 GMC Sierra 4.8 RCSB 2014 Explorer (wifes) My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148 Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583 |
12-12-2008, 08:09 AM | #10 |
I have done this about a dozen times. Some work, but worth the time. Cutting the old std trans.crossmember out is the part i hate the most. Hope this helps.
55 Chevy original swb (big back window) 61 Chevy bubble top (427-5 speed) 67 Chevy stepside (Krusty) 68 Chevy swb fleet (Lola) 68 Chevy swb fleet 71 Chevy swb fleet ( future PB project) 97 crew cab power stroke 07 SS Trail blazer |
12-12-2008, 08:34 AM | #11 |
Don't forget, the flywheel to crankshaft bolts on an automatic flexplate are shorter than the bolts from a manual transmission flywheel. Just keep the bolts that held the flexplate on the van and you're good to go there.
The bolts that hold the torque converter to the flexplate will need to be saved and reused from the van too.
'70 cab, '71 chassis, 383, TH350, NP205. '71 Malibu convertible '72 Malibu hard top Center City, MN |
12-12-2008, 08:48 AM | #12 | |
1997 GMC Sierra Ext 1965 Mustang |
12-12-2008, 09:22 AM | #13 |
Being than when we did it I was also putting in a new engine it made things a hell of alot easier. The crossmember was a piece of cake with the engine out of the way. Doing it this way was the best thing to do..see pict below.
12-12-2008, 11:11 AM | #14 | |
Watch out for your cornhole !
12-12-2008, 01:16 PM | #15 |
mini truck racer
What nose cone is this for future reference ? I started 2 threads on this and never got an answer . I put a 168 tooth flywheel on it .
12-12-2008, 01:37 PM | #16 |
Left one is off a straight stick truck, right off of an auto tranny truck.
12-12-2008, 05:38 PM | #17 |
Yep. Where can you find just the nose piece?
12-12-2008, 07:02 PM | #18 |
I just collect old unworking starters when I run across them.
There are really only 2 different nosecones to worry about, straight bolt pattern and staggered bolt pattern. The small flexplate uses a straight across pattern. I just poked through my pile of starters till I found a junker with the proper nose cone. If memory serves me correctly, it was a small block powered 80s vintage Camaro.
12-12-2008, 10:43 PM | #19 |
the one on the right looks to be from a buick v8 ( 350 - 455) or a 153 toothed flywheel small chevy . the later 168 toothed had both the longer two bolts and where staggered
'70 k-10 longbox- mid 70's drivetrain 350/350 487x heads 10.1:1 flowmasters ,35's 3.73's auburn posi ,rear shackle flip. '72 short stepside U.S. forestry truck, '73 455 buick,400 turbo,dropped 2"-4 1/4" ,3.07 posi,:'89 silverado 1500 ,OK truck ,5.7 holley tbi ,trick 700r4 3.07 auburn posi ,and my '66 skylark ,'73 centurion and my '84 monte carlo imca stock car |
