Old 12-12-2008, 05:50 PM   #1
budman k20
1972 K20
Question What rear diff do I have?
Help!
I went to the parts store today to try and buy seals and cover gasket. Without knowing what type of rear end my truck has it seems there are two choices Dana or GM. Can someone tell me what rear end my truck has...without pictures! It is a 72 K 20 (3/4 ton 4wd) and the rear has a removable 3rd member or center section and also has a removable rear cover that is round. 8 lug floating bearing axle on leaf springs
budman k20 is offline   Reply With Quote
Old 12-12-2008, 06:09 PM   #2
Rack Man
Re: What rear diff do I have?
Here...check out this ID Chart....
http://www.coloradok5.com/axleguide.shtml
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288
Rack Man is offline   Reply With Quote
Old 12-12-2008, 06:14 PM   #3
Cyclone
Cyclone's Avatar
GM (eaton)
Heres a Dana cover for referance:
Cyclone is offline   Reply With Quote
Old 12-12-2008, 06:36 PM   #4
budman k20
1972 K20
Wow,
Thanks for the quick reply guys. From looks I must have the GM (Eaton) rear. Is that normal for 3/4 ton trucks? Is it called a 10 bolt? The parts guy asked and I assumed a 3/4 would have 12 or more?
Old 12-12-2008, 06:41 PM   #5
Cyclone
Cyclone's Avatar
Eaton is most common/normal for 3/4.Its not a 10 or 12 bolt, its an Eaton.
Old 12-12-2008, 08:45 PM   #6
sweet70beast
sweet70beast's Avatar
I believe in 72 and earlier 3/4 ton the eaton is the only axle that came in 4x4s. 2wds could have either one depending weither it was coil or leaf. I am by no means an expert but all the coil spring 3/4 tons I have seen have the eaton and all the leaf 3/4 tons have had the dana.
1970 Nova 327/T5 (my 1st car)
1971 K-20 350/350/205 (winter DD)
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1972 Skylark (suncoupe)
1 of 3943 made
sweet70beast is offline   Reply With Quote
Old 12-12-2008, 10:01 PM   #7
1969 GMC
1969 GMC's Avatar
My '69 GMC K2500 came stock with a D44 front and D60 rear, 4.10's. It's also interesting to note that the D60 rear that was under this truck had 30 spline axleshafts...fords and dodges of the same vintage seem to have the coarser splines.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 12-14-2008, 12:50 AM   #8
sweet70beast
I saw a neighbors 67 K20 today and sure enough it has a dana 60 rear. Learn something new everyday.
1953 GMC Suburban
1968 Chevy Bel Air
1976 Chev C-10
1 of 3943 made
Old 12-14-2008, 12:57 AM   #9
72-c20
Packrat
72-c20's Avatar
specifically, it's an Eaton H052 rear end. I got my pinion seal for mine at NAPA...
gone: --'07 Tahoe LTZ 4WD
--'68 Firebird 400 Convertible
gone: --'72 Chevy K20
72-c20 is offline   Reply With Quote
Old 12-18-2008, 11:42 AM   #10
Elephanthead
Is that bolt on the Eaton H52 cover where you fill the gear oil up too?
Elephanthead is offline   Reply With Quote
Old 12-18-2008, 11:47 AM   #11
budman k20
1972 K20
Yes it is...
Old 12-19-2008, 05:35 PM   #12
CPNEJR
CPNEJR's Avatar
typically 3/4 ton 2wd and 4wd chevy's had an Eaton HO52. GMC's had a Dana 60. my dads 72 GMC K2500 has a Dana and my 70 and 72 K20's have the Eaton. the Eaton parts can be harder to find also.
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 12-19-2008, 06:00 PM   #13
Dooley
Dooley's Avatar
My 1972 1ton 8.5' longbed 2wd GMC had the leaf spring Eaton rearend.
Dooley is offline   Reply With Quote
Old 12-20-2008, 03:59 PM   #14
mothertrucker424
mothertrucker424's Avatar
were are parts avalible for the eaton rearend and how can i upgrade it and any good write ups?
_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-
1972 K10 4"lift 33"tires (soon to be bigger and better)
2000 silverado 1500 2wd 2"coil spacers3" BL 285/75/16's
mothertrucker424 is offline   Reply With Quote
Old 12-20-2008, 06:11 PM   #15
1969 GMC
1969 GMC's Avatar
there are not many aftermarket products for them, the only one I can think of off the top of my head are disc brake brackets.
however they are fairly beefy. I have never seen or heard of a broken one. The No-Spin (Detroit locker) is now discontinued for the application, however a 14 bolt diff will swap into the Eaton's carrier, provided you switch to 14 bolt axle shafts. there are a number of lockers or minispools available for the 14 bolt, and these will swap into the eaton.
there were aftermarket gears being sold in 3.90 and 4.11 and perhaps some other ratios, but i don't believe they are available any longer. All bearings in the center section and the wheel bearings are on the shelf type parts at the parts store. some of the brake hardware may be hard to find, but there are always disc brake conversions.
eatons are a bit lighter than 14 bolts also due to the sheetmetal axlehousing, which can be a good thing.
if you search, there is plenty of information here on these rearends. you don't have to throw it away just yet.
1969 GMC K2500
1996 Honda Accord
