12-12-2008, 07:23 PM | #1 |
Qjet won't kick down
when it was warm, my 84 C10 with a 350 and Q jet carb ran fine. Now it's cold and it idles high and I can't get it to kick down. it has power going to the electric choke. what should I check? thanks
12-12-2008, 09:28 PM | #2 |
The One And Only !!!
Re: Qjet won't kick down
Larry,
I would test the choke with a multimeter to make sure it has a closed circuit, It could be blown. Also check your high idle cam and linkage on the carb for any binding/stiffness. Good Luck
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
12-12-2008, 09:57 PM | #3 |
ok, thanks, I'll check the ground
12-12-2008, 11:15 PM | #4 |
It's not really a 'ground' your checking, Un-plug the wire and set your meter on ohm's scale. Touch one test lead to the wire connector and the other to any part of the carb, You should get a closed circuit reading if not the heater windings are blown.....
12-13-2008, 11:43 AM | #5 |
are the choke windings able to be replaced?
12-13-2008, 04:41 PM | #6 |
No, Just replace the choke assembly then adjust while the engine is cold.
12-13-2008, 05:40 PM | #7 |
Sb 400 club
I also have a Q- jet question. On my 77 with a 350 if i tap the pedal it kicks down but when I place it back into park after driving it idles high again. Any ideas what could be causing this.
thanks
1984 chevy c10, built 400sb,.(SOLD) 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
12-13-2008, 06:44 PM | #8 |
its a QJET thats why i got a eldy
http://67-72chevytrucks.com/vboard/group.php?groupid=37 73 C10 Fleetside If it ain't a Chevy it's foreign http://hotridesmag.com/ |
12-13-2008, 08:43 PM | #9 |
Sb 400 club
I have an eddy on my 84 and love it. easy to tune and runs dead on all the time. But I am not switching to an eddy on my 77. If anything I will rebuild th e Q jet 25.00 for a rebuild kit and a half hours worth of work.. Anyone have ideas on mine kicking down but idling back up when placed in park? Thanks
12-13-2008, 10:20 PM | #10 | |
Could be a couple things, When it idles high in park after driving can you tap the gas and have it idle back down ?
12-14-2008, 05:26 PM | #11 | |
Just here to tinker
OK, More than likely your fast idle cam is sticking on the first cam step. One reason could be that your choke pull-off is not operating properly. That cost's about 15 bucks and is a pretty important component that most people overlook during a rebuild. What style choke do you have? Electric, divorced?
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
12-14-2008, 09:24 PM | #12 |
Sb 400 club
yes when placed back into park it idles high but will kick down with a tap of the gas. I am not sure what style choke it is . I will have to take a closer look on friday and get back to you.
12-15-2008, 07:42 AM | #13 |
Georgia Boy
More than likely it's the pull off.. I've seen that happen alot.. and a sticking linkage. WD40 it. QJets are awesome carbs.. I have a 780cfm version that I had professionally built. Crisp, clean response that's like a lightswitch. I get good mileage and equal or better performance than any Edelbrock or Holley.
81 GMC High Sierra, 2WD, 357ci/700R4, 3.73s, posi. |
