Roadtrip!
![]() Join Date: Feb 2003
400 sb
Just stumbled across a 400 small block 4 bolt main. Just a block. Guy wants $100 for it. Is it worth getting? I prefer the big blocks myself, but i know these aren't very common either. Any advice or opinions? Thanks, Eric
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
Re: 400 sb
ABSOLUTLY!! 4-bolt blocks were only made for a couple years.
Re: 400 sb
Eric, yes i would ,its worth 100 all day .they are getting harder to find imho
Re: 400 sb
Check it out VERY carefully....lots of cracked block 400's out there. I had a buddy who bought one once....not good.
If the block is good it's a bloody steal! 400's are excellent small blocks!
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. Last edited by Gray Ghost; 12-12-2008 at 08:28 PM. |
Re: 400 sb
You need to have it checked for cracks around the mains because the 4 bolt cap bolts are in a very thin area of the block and are known to crack but if not the price is great.
Troy 1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884 Big Red Dog build http://67-72chevytrucks.com/vboard/s...d.php?t=572274 |
Re: 400 sb
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild |
Formerly- 1972SuperCheyenne
![]() Join Date: Oct 2008
Re: 400 sb
Two bolt blocks are stronger than the 4 bolt blocks when it comes to a small block 400. Have it checked for cracks very carefully before dumping any money into it.
--Josh My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218 A good crossthread is better than Loctite any day. Life is not about what you have, but who you have to share it with. |
Roadtrip!
Re: 400 sb
Thanks for the opinions. I guess i will have to check it out better when i get a chance. He has a few other engines there too. I will update this when i can...
![]() Join Date: Jan 2008
Re: 400 sb
Also check the bore, you don't want it if it's already .030 and needs to bore again.
Re: 400 sb
I would look it over really close also. The lifter valley cracks on them as well. Otherwise you have a $100 boat anchor. The "4 Bolt" term is highly over rated IMO.
