Old 12-12-2008, 08:04 PM   #1
Chevy4Life86
Chevy4Life86's Avatar
Engine conversion questions
i have a 1970 Chevy C-10 1/2 ton 2wd with a 350 and automatic trans. I am planning to pull the 350 out and put a 396 Big Block in it. What all will I need to do to make the conversion work well so the truck is relaible. I know i need a Big Block radiator, Turbo 400 tranny but after that im clueless if I need anything else. any suggestions would be appreciated. PS: im only doing the big block conversion because the 350 needs a total overhaul and the 396 is ready to go.
1963 1/2 ton 2wd 350/4 Speed
1970 1/2 ton 2wd 350/Auto
1968 Dodge Charger(driver) 383 2 barrel/Auto 2.76gears
1977 Chevy Nova 4 Door 250/Auto(had 45,000 miles from new)
1966 Plymouth Fury II 4 Door Sedan 318 Poly Head/Auto. (driver)
1998 Pontiac Grand Prix 4 door 3.1V6/Auto
Chevy4Life86 is offline   Reply With Quote
Old 12-12-2008, 08:35 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Engine conversion questions
you looking to just shove it in there, or you looking to do it like it came with it there?
Old 12-12-2008, 08:42 PM   #3
Chevy4Life86
to shove it in as cheap as possible without having to replace stuff in afew months.
Old 12-12-2008, 08:43 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Engine mounts, fan shroud, pulleys, brackets, and exhaust.
