Old 12-13-2008, 01:57 AM   #1
Bazooka
Keepin it old school
Bazooka's Avatar
Best way to replace my 1 piece Drive shaft with 2 piece??
I was wondering whats the best way to go about changing out my 1 piece drive shaft to a 2 piece??
Do I need to visit the junk yard?? What all do I need to do this? Need all info possible.. Don't know anything about them..
My truck is going full air ride and will be laying flat frame with the SD raised crossmember. I want to switch over to the 2 piece so I don't have to cut the cab floor for driveshaft clearance..
Any help is appreciated!!
Bazooka is offline   Reply With Quote
Old 12-13-2008, 05:32 PM   #2
Bazooka
Bazooka's Avatar
Re: Best way to replace my 1 piece Drive shaft with 2 piece??
Anyone??
Old 12-13-2008, 05:52 PM   #3
2manyprojects
2manyprojects's Avatar
My 65 short wheelbase panel 3spd has a 2 piece. That would probably work. I'm going to use a 1 piece. If your interested I might let that one go. The center bearing bolts to the trailing arm cross member should be a easy swap
65 Chevy C10 Panel http://67-72chevytrucks.com/vboard/s....php?p=7148391
42 Chevy 3100http://67-72chevytrucks.com/vboard/s...92#post7184392
96 GMC K2500 Diesel Suburban
89 GTA Trans Am Convertible.
2manyprojects is offline   Reply With Quote
