Old 12-01-2002, 08:36 PM   #1
spinning wheels
spinning wheels's Avatar
steering column ?
Hello, I need some info on a steering column problem, this is on a '72 3/4 GMC. It seems that I can pull on the steering wheel and it will pull out about a half inch or so. I was told my column was worn out. I priced a rebuilt tilt steering column, they sell at the local swap meet for about $250. Not sure if this is a good price or do I just need a new steering coupler? Any info? Thanks
'72 GMC custom camper 350/350
spinning wheels is offline   Reply With Quote
Old 12-01-2002, 08:41 PM   #2
racedvl
racedvl's Avatar
Ya know, not to be a smart ass, but mine does that too, I just don't pull on it.
racedvl is offline   Reply With Quote
Old 12-01-2002, 08:45 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
My first two did that...but I can't remember on the one ton...the steering wheel has been off for so long I just can't remember.
I know if the upper bearings are shot, it'll cause some slop, but I doubt that's the problem the way you describe it.
Old 12-01-2002, 08:47 PM   #4
racedvl
racedvl's Avatar
I bet a new rag joint would help.
Old 12-01-2002, 08:48 PM   #5
Longhorn Man
I doubt it...the shaft shouldn't pull through the column regardless of the rag joint.
Does it have up and down slop in it too?
Old 12-01-2002, 09:06 PM   #6
imaindianoutlaw
GMC SHORT FLEET F/S
imaindianoutlaw's Avatar
Humm?
CHARLES WADE HEIN
HVACR FOREMAN.
LEWISBURG U.S.P.
imaindianoutlaw is offline   Reply With Quote
Old 12-01-2002, 11:17 PM   #7
spinning wheels
No up 'n down slop. And not much slop in the steering either.
Old 12-02-2002, 11:00 AM   #8
racedvl
racedvl's Avatar
I dunno, I would have someone pull on it while you were under the hood. See where the pull comes from. I would think a rag joint, would help some of that.
Old 12-02-2002, 11:06 AM   #9
slam33
slam33's Avatar
LMC has all the stuff to rebuild it and it's not that hard to do. I did the one in mine. You should be able to pull it, rebuild it and get it back in a day.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
Old 12-02-2002, 11:21 AM   #10
JimKshortstep4x4
Talking
There should be a spring at the lower end of the steering column
which holds the upper and lower bearing in a preload. If you pull
up on the wheel, you can overcome the spring and the wheel will
move approximately 1/4". You may want to check the spring and make sure it is in place. Also, there should be a large thick washer between the spring and the coupling.
Jim
Old 12-02-2002, 12:34 PM   #11
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Mine does the same thing. Since I have some lame aftermarket steering wheel, I can see the upper bearing. When I pull on the wheel (actually, all I have to do is just touch it) the upper bearing will come out of it's possition. I have looked under the hood and the problem is not in the rag joint. I believe that mine is missing the spring JimKshortstep4x4 mentioned and possibly some retaining clip or spring on the upper bearing. I have considered rebuilding it but I just haven't gotten around to it yet. I have noticed they have the parts in LMC but I'm not sure what all I need yet.
Let us know what parts fix yours if you decide to rebuild.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 12-02-2002, 08:08 PM   #12
VDOG
Grand PooBaa Member
VDOG's Avatar
I had that same problem. I went to the junkyard, found a Chevy van, about a 76 or 77. Pulled out the tilt column, and called it a day. 45 bucks allday long. Problem is, some people will tear then up trying to take them out. If you find one not too badly damaged, buy it and get it repaired. I like the Lokar, but dont have the 550.00 to pay for one.
VDOG is offline   Reply With Quote
