Old 12-13-2008, 12:16 PM   #1
ol Curt
Junior Member
ol Curt's Avatar
oo Silverado FPR problems
Any of you had problems with a fuel pressure regulator making noise after it was installed? Mine makes a lot of vibration when it is cold outside.
ol Curt is offline   Reply With Quote
Old 12-13-2008, 12:19 PM   #2
ol Curt
Junior Member
ol Curt's Avatar
Re: oo Silverado FPR problems
I should also mention that I have the 5.3L and I installed the FPR to help with a hard start problem. That didn't cure the hard to start till I found a vacuum leak in the fitting that attaches the vacuum line to the regulator. Replacing that solved the hard start, but that's when the vibration started.
Old 12-31-2011, 02:59 PM   #3
pjmoreland
pjmoreland's Avatar
Did you ever get your FPR vibration problem fixed? My '00 Tahoe has the same problem.
pjmoreland is online now   Reply With Quote
