Old 12-13-2008, 01:03 PM   #1
malexander44
cheap lowering shocks
Hey guys...
I've got a 63 that I put 3/4 drop springs on. My questions is my rear shocks have seen better days and I would like to put new shocks on the front and rear. Does anyone know of a cheap alternative to lowering shocks that would work. Would stock shocks work? Or is there another truck that has the same type of shocks with a different travel length then ours?
Mark
malexander44 is offline   Reply With Quote
Old 12-14-2008, 03:24 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: cheap lowering shocks
Anyone?
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-14-2008, 05:38 PM   #3
LONGHAIR
You should be able to find something on a cross reference sheet. You just need to match up end styles and lengths.
LONGHAIR is offline   Reply With Quote
Old 12-14-2008, 05:47 PM   #4
vin63
It's Better With Nitro
vin63's Avatar
We used a set of Monroes (Monro-Matic Plus - part no.: 33033) for the front on the rear of my buddy's '66 recently since they're a little shorter. It worked out perfect for his lowered rear end and it didn't provide such a harsh ride.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-14-2008, 08:35 PM   #5
mycool72
mycool72's Avatar
I used air shocks on my 05 with a 4-6 and it rides ok, not great, but ok...you can air them up or down to get the ride that you like.
mycool72 is offline   Reply With Quote
Old 12-16-2008, 08:05 PM   #6
MEANlowGREEN
Registered Asphalt Offender
MEANlowGREEN's Avatar
I'm using Doetsch Tech Drop Shocks from CPP (Classic Performance Parts) They are fairly inexpensive but may be more than you wanted to spend at around $30 each. They are great shocks though and rde like a cloud...
It's not too low unless the tires won't reach the ground anymore!
1963 C10 Short Fleetside Bed Big Back Glass
1974 C10 Short Stepside Bed
1982 S10 Shortbed 350 EFI V8
http://67-72chevytrucks.com/vboard/a...hp?albumid=140
http://www.hubgarage.com/mygarage/MEANlowGREEN
http://www.motortopia.com/garage/cars/MEANlowGREEN
http://www.myspace.com/jcsmeed
MEANlowGREEN is offline   Reply With Quote
Old 12-20-2008, 07:56 PM   #7
XXL
Seņor Member
XXL's Avatar
I found a lot of good information using the search feature on this forum.
XXL is offline   Reply With Quote
