12-13-2008, 03:54 PM | #1 |
Must you remove manual crossmember when going to auto???
I know I know......I searched...the search function on here is dsyfunctional at best....
Anyhow, when going to auto.....in this case from a 350/ 4 speed to a 5.3/ TH400, MUST you take out that pain in the ass looking bellhousing holding crossmember because it sure doesn't look very fun or easy. Will the auto fit around it or no??? Anyone ever leave theirs in? |
12-13-2008, 04:08 PM | #2 |
Re: Must you remove manual crossmember when going to auto???
You'll need an auto crossmember instead of that one. Never heard of anyone retaining it but I don't know it all. I got mine for $50...they're cheap!
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. |
12-13-2008, 04:09 PM | #3 |
I have the auto xmember figured out, just trying to get around having to cut this original manual out if the trans will fit in around ill just leave it
12-13-2008, 04:10 PM | #4 |
I took mine off because you have to...
I bought the auto crossmember from Classic Perform....
Get your facts first, and then you can distort them as much as you please!!!!!. Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild Last edited by big_al_71; 12-13-2008 at 04:12 PM. |
12-13-2008, 05:12 PM | #5 |
Project Junkie! Fishing Poor!!
You will have to remove the manual tranny crossmember. You won't be able to clear it with the bell housing to install or remove the auto trans. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
12-13-2008, 06:31 PM | #6 |
thanks guys.....air-hammering it out now
12-13-2008, 06:46 PM | #7 |
Sorry there's no short cut...I hate cutting those out too...last time I did it I used up three sawzall blades [no air tool I had would budge the rivets].
12-13-2008, 06:55 PM | #8 |
Im super impressed....borrowed a buddy's mac air hammer....knocked each rivet out in less than 10 second......cut the member in half right in the middle real quick and tapped it with a hammer.....out in about 10 minutes.....wooohooooooo
12-13-2008, 06:59 PM | #9 |
The Older Generation
Mines still in place in the '70 Chevy. I have an '86 Camaro TPI/700r4 in the truck... I also have new motor mounts all the way around. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 12-13-2008 at 07:00 PM. |
12-13-2008, 08:05 PM | #10 |
Old member
I just cut a section out of the middle and left the sides with a 700-R4 in it now.
12-13-2008, 09:20 PM | #11 |
sharp as a marble
I removed my Manual x member in one piece, unlike mellow yellow, Cut the rivets out, and have a GOOD manual crossmember,linkage,trans, shift coulmn for sale. When you change from manual to auto the manual x member has to go
12-13-2008, 09:29 PM | #12 |
Chevy nut
I used a 4" angle grinder to get the two I had out. I took longer...but I got it out in one piece.
84 Chevy Custom Deluxe 1/2 Ton Named Fade To Black II "Remember kids there is NO replacement for displacement!" |
12-13-2008, 10:03 PM | #13 |
it looks like if your truck is a 3 or 4 speed truck and making it auto cost more money
