Old 12-13-2008, 05:04 PM   #1
68SWB4x4
Strongman Garage
68SWB4x4's Avatar
front axle casting #s
I got some casting #s off a 10 bolt front. trying to figure out the gear ratio.... These are casting numbers from the underside of the pumpkin on the inside.
14030876
6
3
Are these the right numbers I think its an 8 but might be a 6 or a 3.
Thanks! if anyone has a website that I can look these up myself that would be great.
68SWB4x4 is offline   Reply With Quote
Old 12-13-2008, 05:55 PM   #2
drbyrdman
drbyrdman's Avatar
Re: front axle casting #s
there will be a metal tag with the ratio attached to the cover. or you will need to spin the wheel a couple turns and count the driveshaft. casting numbers wont tell you the ratio.
drbyrdman is offline   Reply With Quote
Old 12-15-2008, 10:05 AM   #3
Roostr84
I am not sure but I would guess those numbers are the stamping for the Bill Of Materials (BOM).
Roostr84 is offline   Reply With Quote
Old 12-15-2008, 02:01 PM   #4
1969 GMC
1969 GMC's Avatar
Is there an easy way to decode that? With dana axles, you can just plug the #s into their website.
It would be easiest to unbolt the diff cover and see what is stamped into the side of the ring gear.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
