12-13-2008, 11:21 PM | #1 |
Adjustable Proportioning Valve - Required for Disc/Drum Setup??
I'm plumbing the brake lines for my 70 K-10 project....I swapped the front axle to a mid 70's Dana 44 w/Disc Brakes (rears are still drum).....I ordered all new SS lines from Inline tube (which 50% are too short)....They also sent me an adjustable proportioning valve...Is this valve necessary even with the regular proportioning valve located at the master cylinder?....or is it meant for fine tuning the rear drums in more of a performance application?
Thanks in advance for any insight you can give me! Dan
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 |
12-13-2008, 11:46 PM | #2 |
It's Better With Nitro
Re: Adjustable Proportioning Valve - Required for Disc/Drum Setup??
Is the proportioning valve near the master cylinder for the front disc/rear drum bias?
12-14-2008, 12:21 AM | #3 |
I have nothing right now...so I guess it could be.....But I'm clueless.....I am in the middle off a frame off resto....so I still need to purchase the MC, power booster & proportioning valve......Just trying to get the main brake lines ran while i'm at the frame level.....
12-14-2008, 12:42 AM | #4 |
Gotcha...many of the master cylinder (MC) kits come with an OE-type proportioning valve assembly pre-plumbed mounted at the MC, and you can specify disc/drum or disc/disc bias. The adjustable proportioning valve is often used inline on the tubing going to rear brakes when you do not have a factory-type proportioning valve at the master cylinder. I run the adjustable type on my rear brakes of my drag car just to make sure there is more braking being done by my front brakes.
12-14-2008, 12:44 AM | #5 |
I don't know for sure if it's absolutely necessary to have it, but I had to have the adjustable one, along with the regular one. Before the adjustable one was installed my back brakes would lock up when I hit the brake pedal.
'58 SWB Fleetside...Front & Rear Porterbuilt Dropmember, 6.0 LS /4L60E. Accuair E-level, 20 Billet Specialties (Vintecs) '63 Buick Riviera ... AccuAir E-level, 20" Billet Specialties (Vintecs) http://67-72chevytrucks.com/vboard/s...=528853&page=5 |
12-14-2008, 02:50 PM | #6 |
Not sure with the regular one involved, but without it yes it is necessary. It takes I believe 10lbs of pressure to make drum brake works and I believe it was 2lbs of pressure to make disc's work. So put it on the disc side to limit it so that they aren't biased towards the fronts locking up.
12-14-2008, 06:02 PM | #7 | |
An adjustable proportioning valve gives you the ability to restrict pressure to one end, to equalize the actual braking. It is usually the back that has a tendency to lock-up, especially when the bed is empty. |
12-14-2008, 09:49 PM | #8 |
The standard prop valve is what you will need to run your disc/drum setup. it can mount near master or down on frame, it does not matter. We have them in brass and SS.
12-14-2008, 11:20 PM | #9 | |
