Old 12-14-2008, 01:35 AM   #1
63Belair
Sub in 62-63
Has anyone installed a sub using a bench seat and with out moving the gas tank?
63Belair is offline   Reply With Quote
Old 12-14-2008, 10:41 AM   #2
vin63
It's Better With Nitro
vin63's Avatar
Re: Sub in 62-63
My buddy in AZ had a box built that was located under the bench seach, it occupied just about all of the space under the seat...I'm not sure what size the speakers were, but that's how he did his. I think anything of significant size would be a problem just due to space restrictions. Good luck and post some photos.
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 12-14-2008, 11:28 AM   #3
tommys66
Re: Sub in 62-63
check in crutchfield. they make a low profile sub with enclosure for that type of application. or I once had a set of bass cannons under the seat which had good sound.
tommys66 is offline   Reply With Quote
Old 12-15-2008, 08:38 PM   #4
the kid
the kid's Avatar
Re: Sub in 62-63
just do a walk through
making trucks pointless 1 at a time
the kid is offline   Reply With Quote
Old 12-24-2008, 08:09 PM   #5
the lights
the lights's Avatar
Re: Sub in 62-63
I did this by making a spacer out of square tubing which raised the seat a little but i was able to install two 12" subs under the seat without removing the tank.
the lights is offline   Reply With Quote
