12-14-2008, 04:08 PM | #1 |
tach help!
i have a super tach iii and i need help on were the light wire goes wich is the white one!
its for to light up the tack at night but im having trouble on were to run it! help me thanks! |
12-14-2008, 04:14 PM | #2 |
Dave's not here, man
Re: tach help!
I tied mine into the the light circuit. My fuse panel has a place on it that is tied to the lights. I just ran the light wire there and it comes on when my headlights do.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
12-14-2008, 04:40 PM | #3 |
its all about the +6 inches
Re: tach help!
yep, the one in the top left on this photo marked cluster feed
12-14-2008, 06:23 PM | #4 |
Gone to greener pastures
Re: tach help!
I am VERY lazy.
When I hook up after market stuff, I just tie the light & power wire together. When the key is on, the light is on. But that's just me & my .02.
'69 Chevy 1/2 T LWB Stepper: Daily Beater '72 GMC 3/4 T Fleet: Another Daily Beater '72 Plymouth Gran Coupe: ? "Ah women. They make the highs higher and the lows more frequent." Friedrich Nietzsche "Never kick a fresh turd on a hot day." Harry S. Truman GUN CONTROL: Never having to say, "I missed you." Always fire two warning shots into your attacker's chest area before putting a bullet between his eyes. Paraphrased from Louis Awerbuck |
12-14-2008, 07:18 PM | #5 |
Re: tach help!
power wire?
u mean the one that goes to the coil? i tried what longhorn said and it still didnt work? why? |
12-14-2008, 07:30 PM | #6 | |
Re: tach help!
The "power" wire is the one connected to the 12 V. switched power to the tach.
12-14-2008, 07:34 PM | #7 |
72 chevys 4 life
Re: tach help!
i just used on of those nice splice things that you dont even have to cut the wire to use them....i spliced mine into the wire that goes the lightbulb in the heater controls....
I dont call it being young and dumb....I call it young and havin fun |
12-14-2008, 07:35 PM | #8 |
Re: tach help!
How many wires come out of the tach? There should be black for ground, red for power and white for the light. What El Jay is saying is that you can tie that red power wire and white light wire together to the power source (12V) and kill two birds with one stone. There should be another wire that goes to the tachometer spade on the distributor (it's green if IIRC) My dizzy is an HEI and I'm not exactly certain how the tach would hook up to a points dizzy if in fact you have one.
12-14-2008, 07:42 PM | #9 | |
Re: tach help!
12-14-2008, 07:51 PM | #10 |
Re: tach help!
I believe there are four wires out of the tach. One to the switch
one to the coil or dist cap in case of HEI. one for the light and one for the ground. I like the idea of tying the tach light into the instrument lights so that you can dim it if you want to. I'm not sure of the color code though. I have two of those and one is missing the harness. Bingo we have a winner!!! http://www.sunpro.com/publish/2007/0...lish_16472.pdf Now I need to save that page before I loose it again. As an added fyi Sunpro (Sun) Has instructions for most all of their gages online in pfd format. http://www.sunpro.com/user_manuals.php Last edited by mr48chev; 12-14-2008 at 07:52 PM. |
12-14-2008, 09:42 PM | #11 |
Re: tach help!
ay guys thanks alot i got it!
